Question about Samsung TV Remote Control
Direct TV remote quits working - conflict with Samsung LCD?
We have a new Samsung LCD TV and paired it with a HD receiver from Direct TV. The remote that came with the receiver works great for at the most 10 minutes and then if you are lucky the volume control continues to work but you can't change channels or bring up the guide. Direct TV has sent three different remotes and no change. This has to be a conflict between the TV and the receiver. What do we change?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Posted on Sep 04, 2009
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Purchased new sharp aquos lcd and when the tv is facing forward the direct tv remote will not work. With tv facing side remote works fine. Seems the picture is interfering with the remote. Direct TV says...
more likely the remote sensor is misaligned in the tv, and it needs to be pulled out straightened and replaced back in , maybe even the receiver board will need to be replaced. they are small in size and if the tv is in warranty then it will be easy to get it replaced.
the picture does not interfere with rf or ir signals the image is passive. to check the remote you could simply tel direct that the remote stopped working (no matter what tel the phone person it doesnt work...
that will get you a new remote and then you will know if it is the tv or the remote.
Jan 31, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have a new Samsung HD tv and have hooked up my DVD player. I have a Directv remote. How do I watch my movies now?
You will still need to use your SAMSUNG remote to switch the source inputs since I do not beleive the DIRECT-TV remote has full function of the SAMSUNG remote.
Nov 02, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Sep 13, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
TV,
RED + SELECT ( blinks twice)
TV,
0060
TV,
SELECT.
Job done
Hope this helps you out.
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Samsung TV Remote Control Logo
466 people viewed this question
Jerry Greenberg
Jerry Greenberg
