Question about Toro Lawn Mower With Toro Power Tools
How do I replace the belt on my toro model 20334 lawn mower
    Novelist:
  • 133 Answers
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from comming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Sep 03, 2009
I need to see a manual for the toro model 20370. I need to replace the drive belt
Take the old belt off and take it with you to a lawn mower shop or even a farm supply place that sells belts and they should mathch you up with the right belt.
Sep 05, 2014 | Garden
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
I have a toro lawn mower. Model no. 20352. The drive belt came off the pulley. How do I reinstall?
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Aug 13, 2009 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
672 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
