Question about Black & Decker 3.6V Gld Battery
The battery charger for my Black & Decker Storm Light VP215
The charger doesn't work. The resistor R& appears to have been overheated and failed. Can you provide me with the Ohms rating for the R7 resistor?
  • 205 Answers
SOURCE: What milliamp is the charger rated at?
9VAC-100mA
this is right off my charger. it also says 6V on it
this is too bad, I have a charger and no tool and you have the tool and no charger
Posted on Mar 26, 2009
  • 449 Answers
SOURCE: My Black & Decker 24
check voltage on prongs of charger your transformer my have died
Posted on Sep 15, 2010
  • 6 Answers
SOURCE: Black and Decker battery charger does not work.
Black & decker chargers and bulbs for the light are JUNK..Don't waste your money on their products.I have 2 chargers for the 24 volt batts-1 is only 2 months old-It blew the fuse {soldered to the circuit board} I'm putting in a fuse holder but don't know the amp of the fuse-I'm starting with a 1 amp slo-blo and going up until it works or goes up in smoke..I had loads of problems with this B&D 3 piece set---It's only 1 year old..Total waste of money..
Posted on Nov 04, 2010
  • 87 Answers
SOURCE: How do I know if my battery is bad or if my
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Posted on Nov 08, 2010
  • 157 Answers
SOURCE: I need a charger for Black & Decker SZ360
Hello. Here is the link to B&D service, and their batteries&chargers page. Try their toll free and I'm certain they will be able to assist you in finding a replacement as well as a dealer closest to you.
http://www.blackanddecker.com/Batteries-Chargers.aspx
http://www.blackanddecker.com/Customer-Service.aspx
Posted on Apr 06, 2011
Battery not charging Black&Decker Fire Storm
Make sure the charger operates first. If it does, try this. It worked for me. Put the battery in the freezer over night. In the morning put it in the sun for several hours. You must be sure the internal batteries are fully thawed. Then recharge normally. You'll get up to 75% capacity back. If this trick doesn't work, then the battery is not repairable.
Apr 21, 2014 | Black and Decker USA Black & Decker Fire...
Can not find a 24 volt fire storm battery
Amazon and eBay both have listings for this battery.
Sep 28, 2012 | Black & Decker Black And Decker FS24C...
My black & decker hp188f4lk battery doesn't charge
Lithium batteries also have a certain lifetime after witch they will not charge no more. Time past and not using for a long time can also result in a dead battery.
Oct 15, 2017 | Camping, Backpacking & Hiking
Black & Decker LITHIUM CHARGER 14.4v to 18v . 90539541. fits A1518L, HP1884L
could be either one. Have you tried another battery? If not I would recommend taking BOTH in for inspection. They have a scanner that can detect if the battery has a problem. If you need to find a service center close to you go to dewaltservicenet.com and they have a locator. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker 14.4v Cordless Lithium...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Hi, my B & D 24v slide in battery charger 5145093-00 stopped working. I've opened the slide-on end, and discovered a blown resistor. The a.c. is still being rectified to approx 26VDC If i knew the...
Hi daggsat, I know this is a longshot but did you ever discover the value for the resistor for you B&D charger. I've got exactly the same problem.
Jun 13, 2011 | Black & Decker Vacuums
I have a black & decker fire storm drill. The charger doesn't seem to charge the batteries. I was wondering if i need a new charger? Is there a number I can call? Please advise.
u can call black&decker and get one that way or go to your local hardware store or the place you bought it from and you should be able to get another one.
Sep 30, 2010 | Black & Decker 18V Cordless Drill/Driver
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Battery charger shuts off when you put in a battery to be charged,reset wont work,unit is getting warm-a Short ?
I have this problem with my black and decker when I tested the leads in the charger they have power, I tried 3 different batteries. I took the charger apart and plugged in the battery, this is when I noticed the 10v + power that I was getting when testing just the charger turned off when the battery was installed, so instead of reading 10v from the charger I was only reading 4v of the dying battery. I removed some covering only to find the resistor burnt black, and the led light with black in it. I am guessing that I could replace the resistor and light if I could tell what kind they were.
Jul 21, 2009 | Makita Drills
Black & Decker 3.6V Gld Battery Logo
256 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
