Question about RCA F36665 36" TV
RCA F36665 36" red picture
The picture is red but I can still see some images.
I've checked the color controls to make sure it wasn't something easy.
  • 1,153 Answers
Do picture have little white lines in it? This could be caused by a bad CRT driver transistor. On the small CRT board on back of tube. The red could be shorted
Posted on Dec 07, 2007
Connecting dvd player to tv
the back of dvd is easy because it only has outputs with color code, the inputs and outputs on the back of the tv are grouped if you look closely on the back. select video 1 as an input on tv, and start with the far left yellow jacks on the back of tv, connect yellow rca cable and check for pic on tv, if not move to next yellow jack on back of tv, until you get a pic, connect the red and white right below the yellow jack that gave you the picture and you should also have sound
Mar 03, 2013 | Konka Televison & Video
My rca hdtv has 3 split screens
T con board responsible for images on screen. If they are messed up, check this board out or replace it.
Aug 23, 2017 | Televison & Video
I trying to hook up the gtd120 to my flat screen i am getting sound however no picture . do i need the s-video wire to see movie? I have all the other wires y-b-r--w. hlep
What you have hooked up(y,pb,pr) is component video which carries the video. The sound is trnasmitted through a different cable, RCA(white and red) probably in your case. You need to make sure taht your component connections are in all the way and are making contact and, taht all three are in the correct inputs on the flat screen. It is easy to confuse the colors and all the connections are close together making it easy to make a mistake, I've done it myself. Once you have established your connections are correct, make sure you go through your TV's menu to make sure you are the right menu screen(TV,DVD, etc.)
Jun 14, 2011 | GE GTD120 System
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
May 23, 2008 | Audio Players & Recorders
Loss Of Blue Color
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Feb 25, 2007 | Toshiba 57H84 57" Rear Projection...
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
RCA F36665 36" TV Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
