Question about Garden
How to adjust mower deck height - Garden
    Novelist:
  • 133 Answers
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Posted on Sep 03, 2009
I have a 38" cut MTD rider, how do i level the deck?
Posted on Sep 07, 2009
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
SOURCE: 2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Posted on Jul 29, 2011
I am trying to figure out how to adjust deck height
most mowers have a lever to raise and lower the deck . that is the height adjustment also then the wheels need adjusted to meet the ground . without a make listed we really can do no more
Sep 03, 2016 | Garden
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Mower deck adjustment
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Deck is not level and mower blades are not the same height
Usually you can solve this problem by leveling the deck. Many mowers have adjustment nuts on the ends of the brackets that attach the mower deck to the frame of the mower. First park your mower on a flat surface like a sidewalk or driveway. Then place a small level on a flat area of the mower deck, then turn the adjustment nuts until the deck is level.
Jul 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do I raise the blades
there should be a big bar on the right side of the mower that changes the deck height. if it only going up a little look for a height limiter dial on the other side of the mower about where the height adjustment bar is on the right side.
good luck and be careful!
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Garden Logo
1,140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
