Question about Sanyo Televison & Video
I have a sanyo hd 1080 model cod LN46A650A1FXZA & the sound keeps cutting out for no apparent reason, & i was just wondering if there is anything i can do to fix this now?
  • Amanda Sep 03, 2009
    no we watched a movie the other night & it didn't do it!
    this same thing happened last yr but hasn't done it again since then, but we don't know what we did to fix it last time!
    thanks i did it & so far it's working great, but i'll be back if it starts messing up again!! :)
    Thank you
    President:
  • 2,777 Answers
Does it do this on every input / signal? A DVD and TV for example will both have sound cut out?
Let me know and I will help you out here.
Thanks
Tim
Posted on Sep 03, 2009
  • Tim Grayson
    Tim Grayson Sep 03, 2009
    So it is only on the channels then, correct? In that case, check the connections from the cable box / satellite box (if you have one) to the back of the TV. Try turning off both the cable box and the TV, then unplug both from the wall. Give them about 2 minutes unplugged and then plug them back in.
    Let me know what you find.
    Tim
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Apr 04, 2012 | Sanyo DP26648 LCD TV
Sanyo 46" 1080.must you use hdmi cable to get best picture?
Yes. HDMI cables are the best for sound and picture quality with an hd signal at this time than anything else. A lot of people can't see much of a difference using HDMI rather than s-video, component / video, or rf cables but there is a slight difference. You will have to have an hd signal or source such as an hd sattelite receiver, an hd cable box, bluray, etc to benefit fully w/ an hdmi cable.
Aug 03, 2010 | Sanyo Televison & Video
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
