Question about Siemens SX66
Software Help I just bought a used Siemens SX-66 PDA and I need the factory software it usually comes with. Anybody out there tell me where to download it?
  • 3 Answers
Xda devolpers (google it)
Posted on Jan 24, 2008
Bought TX but have no desktop software cd
Yes if you go to you will find a section for support. You can download everything you need there to get your PDA up and running. Once you have the software installed on your computer you will want to go in and enter all your information like names and addresses in your contact section. Once you have that all done you connect the PDA to the computer by using the usb cord and then hit HotSync. You can go back later and update any of your infomation right in the PDA itself. Best wishes. Let me know if you need any other help with this.
Aug 11, 2009 | Palm TX Handheld
Route 66 stuck on the welcome screen (Route 66)
Get the update for Mini/Maxi route 66 from 183 Mb. Install this with card reader on the the SD card.
Then ,having the same problem, Route 66 will start up as usual.
Jan 11, 2009 | Route 66 MINI Handheld GPS Receiver
Sx66 to tmobile
As I understand it, the SIM card is what tells your wireless unit which service provider to use. If you have an old phone, it should be an easy matter to take the t-mobile SIM card out of it and install it in the SX-66. One note on the SX-66: the SIM card on mine had a tendency to lose contact (and my contacts would disappear) from jarring until I put a piece of scotch tape across the bottom of it. No problems after that.
Nov 29, 2007 | Siemens SX66
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Can not connect my PDA
Hi __Try to Uninstall the toshiba software. Also search for the Folder called Toshiba and remove that as well.____Then Re-Boot Your machine. ____Re-Install the Toshiba software and that should work.____If not we can do a live meeting and I can help you troubleshoot the problem.____VR____JustAskMe
May 04, 2007 | Toshiba e405 Pocket PC
PocketPC e570, Is there an opportunity to set it back to factory default?
you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
Sep 11, 2005 | Toshiba Genio e550
E570 with GPS and Navi
Personally I have not GPS on my PDA but there is no reason that it should not work properly. The only thing is that you should pay attention on several things. Check by software producer if the software is compatible to your PDA. Please also be careful which ports use GPS hardware because your PDA has no USB port just serial port. With another words check all this important things before you buy anything.
Sep 11, 2005 | Toshiba e570
Connection problem
Have you considered software running in the background on your computer? Usually firewall/anti-virus software can block the connection. If you are running any Norton or McAfee products, it is likely the cause. Try disabling them, or boot into safe mode with networking support and see if the PDA responds from here. Safe mode loads a minimal set of drivers and no startup programs. Goodluck!
Sep 11, 2005 | HP iPAQ HX2755 Pocket PC
Siemens SX66 Logo
153 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
