Question about Little Tikes Sports Car Bed Frame Police Car
I bought a second hand blue car bed for my son...cleaned it outside w/soad and warm water, then hosed it down. Now there is water inside the car, how do I get the water out?
The only way to get the water out is to drill small holes on the bottom of each part and let the water drain out.
Posted on Jan 08, 2010
Floor board on passenger side wet after running a/c unit 2005 ford taurus
Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean. Then close the doors/windows and switch to MAX A/C. Check for water dripping. If it stops dripping, water is freezing inside and now you know why!
Aug 13, 2011 | Ford Taurus Cars & Trucks
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
After engine gets warm it gets very hot in minutes
How do you know the water pump works?
Is the radiator clean outside and inside?
Remove the hoses and flush it out.
Is the thermostat in upside down?
Have you pressure tested for a bad head gasket? Leave the rad cap off and look for bubbles.
Aug 03, 2010 | 2004 Nissan XTerra
I bought a used yamaha TTR125 for my son. It
does it have a choke ? if it has a choke you need to choke it and warm it up, sounds like the carb might need cleaned/repaired...
Mar 28, 2010 | 2004 Yamaha TT-R 125 L
New xbox 360 with 2 games playing both ok on xmas day and 2 days after played ok in the morning moved unit upstairs onto sons tv will now only play one game
I Suspect the second game is dirty. try cleaning it, with a cloth wiping from the inside of the disk to the outside. You can use warm water an a smidgen of dish soap if you have some sticky crud on it. just make sure you rinse it well. If you have no luck with that i would suspect a dirty lens in the machine. Try a lens cleaner disc.
Dec 27, 2009 | Microsoft Xbox 360 Console
Leaking water
we had the same issue, and it turned out that our filters inside the unit (the indoor unit) were pretty dirty and needed a clean, and also the run-off pipe/hose was blocked with a sludge, etc. We had to clean the filters inside just with warm soapy water and then blow up the hose outside and it fixed it pretty much straight away.
handy tip - take your mouth off the hose quickly, as the sludge will come out of there pretty quickly as the handy one found out!
Aug 18, 2008 | Fujitsu 18C1 Air Conditioner
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Little Tikes Sports Car Bed Frame Police Car Logo
565 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
