Question about Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Pony won't start
Replaced battery. Replaced spark plug. When turning key to start the engine cranks for a second, then seems to bog down and then nothing.
  • g_redinger Sep 06, 2009
    Fixed the problem, had to reset the valves on the engine.
    Novelist:
  • 133 Answers
Try taking the shroud off of the motor and and cleaning the magnets on the fly wheel. Also clean the two little prongs next to the fly wheel. You can also clean the end of the spark plug cable that hooks onto the plug. I use fine sandpaper or emery cloth.
Good Luck
roundo4
Posted on Sep 04, 2009
TROY BILT PONY CRANKS, BUT WONT START
carburetor is more than likely gummed up. you will have to remove carb and clean out jets. one way to check is to get starting fluid and spray into carb while someone cranks it and see if it runs. if it runs then the carb is dirty. and if it does not then check spark.
Aug 20, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Troy Bilt pony will not start
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
Nov 13, 2013 | Troy Garden
Troy bilt pony riding mower
spray some carburetor cleaner in the intake and try to start it if it starts for a few seconds the carburetor is dirty and needs cleaned. put a new needle in it they are cheap and will solve your problem. take the spark plug out and try to start it. if it spins over freely and blows gas out the hole it is the needle in the carburetor. you may want to check the valves, they may be out of adjustment causing hard starting.
Jul 17, 2017 | Garden
Troy bilt pony 17.5 won't start and wires heating up
low battery or weak starter pull plugs spray pb blaster in cylinders make sure it isnt siezing up on you
Oct 11, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My Troy riding mower Pony will not start .. Turn the key and nothing not even a click. I just replaced the ign because of this issue and it still nothing
Have you replaced the battery or the starter? I would start with the battery because if you do not keep the battery warm over the colder months it will drain without the ability to hold a charge.
Aug 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My troy bilt 17.5 hp 42" riding mower won't turn over. The engine tries to crank, but there is no spark in the spark plug. We replaced the fuel filter, battery, coil spark plug, and it still won't crank....
If it is a Briggs & Stratton engine, go to the side of the engine just forward of the dipstick tube and you will see a plug with one black and one grey wire. Disconnect this plug, then repeat the spark plug test. If you now have spark, it means that either one of your safety switches (or the wiring to them) is faulty. If you still have no spark with this plug disconnected, you have either a faulty ignition coil, a short in the cutout wire to the coil, or a faulty spark plug.
Jul 16, 2017 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy Bilt Bronco 5.5 hp that will start and run about 5 mins then cut off the it will restart for like 2 seconds. It's got new plug and clean gas, it's also only about 3 yrs old. Any ideas
Sounds like fuel starvation
Check / remove carby / strip down / check for blocked jets for contamination.
Check spark is present.
Is correct heat range
Mar 16, 2010 | Troy-Bilt Pony Garden Tiller
I need a owner's manual for a early 80's Troy-bilt Horse tiller It hasn't been used for a couple of years and we can't get it started. Want to make sure I have the correct spark plug and the correct fuel...
Ebay has manuals on CD for $6.99 with free shipping. If the spark plug is firing when you crank the engine you probably have a gummed up carburater and it will have to be cleaned. They will do this when they set for a while. Not sure if that will have points and condenser or not but if it does and will not fire they will have to be cleaned or possible replaced also.
Feb 20, 2010 | Troy-Bilt Pony Garden Tiller
Motor seems to be seized
ensure that the motor oil in it was not presivation oil. some machines have a thick oil put in it to stop the engine rusting if stored for a long time this needs to be replaced before starting the engine. if the engine oil is dark and very thick this may be the case and the engine will need to be stripped to dislodge the piston. but that usually happens in a longer time than 10 seconds.
if not then suspect the motor has had some major mechanical failure such as a crank shaft break. remove the injectors or plugs to see if the motor will crank round without compression.
Jan 01, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt 5.5hp Self Propelled Mower Logo
498 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
