Question about Canon PowerShot SD1100 IS Digital Camera
Camera fell into pool; was retrieved in 3 sec.doesn't work
PowerShot A640....hope drying overnight will cure it. Can it be fixed?
  • 428 Answers
You said, "Camera fell into pool; was retrieved in 3..." But you failed to specify if 3 is seconds or minutes or hours. If 3 is seconds, i.e. you retrieved the camera in 3 seconds, then you should be in luck. The first thing you should have done is pull out the battery/batteries. This is to ensure that there will be no leakages of electric current across the electronic components. This is what actually will destroy the camera. Once the batteries are out, the camera needs to be dried. But to be sure that the camera dries well it needs to be opened up. This is the only way you can be sure that there isn’t still some water lurking in a tiny space/corner somewhere inside the camera. What this means is you need to take it a proper technician. Your dealer should be able to provide one. However if 3 is in minutes then you may not be in much luck but you should still take it for repair for a proper assessment.
Posted on Sep 04, 2009
How to remove moisture from canon ixus 130 camera screen
Over time it should dry. Chance of moisture in other parts of camera? Suggest removing batteries and not using at all until you are sure no moisture inside that could cause electrical damage. My
Powershot fell in a river while hiking and simply let it dry out over a few weeks. The screen has internal blemishes, but that doesn't affect the photographs.
Aug 25, 2011 | Canon PowerShot SD1400 IS IXUS 130...
My camera fell in the swimming pool. Will it still be fixed or no? thank you
Your only hope is...
if you have not tried to start it yet...
then place it in a bag of dry rice, and change the rice a few times...
making sure the camera is completely dry before turning it back on...
Then maybe...
heatman101
Aug 04, 2011 | Canon PowerShot SD940 IS / IXUS 120 IS...
My canon powershot a640 comes up with the message...........................NO MEMORY CARD i have eliminated the memory cards, what else can it be?
The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out.
Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card).
In this link could find some troubleshooting tips: fix-for-memory-card-error.
hope helps.
May 03, 2011 | Canon PowerShot A640 Digital Camera
My powershot a640 dropped in the water i want to know if still can be repair or fix and how much it will cost
Sorry, but the damage caused by water is very nearly as bad as if you had your camera crushed or burnt. The result is the same though: your camera is completely beyond any hope of economic repair.
The only realistic fix is to recycle your camera and buy another.
Sorry that my answer is not as you wished for, but I hope that it has still been of assistance to you in deciding what to do next. Please take a moment to rate my reply.
Sep 29, 2010 | Canon PowerShot® A640 Digital Camera
I have a canon powershot A640 when you press the on button it wil
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Canon Cameras
Lense Error, Reset Camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 28, 2009 | Canon PowerShot A640 Digital Camera
Powershot A640 Buttons not responding
I would call Canon tech support and set it up for service. They will let you know what your options are. 1-800-828-4040.
Hope this helps!
Jun 02, 2008 | Canon PowerShot A640 Digital Camera
Black screen on my Canon PowerShot A640
I had this problem too. Try the "DISP" button (bottom left on the display side of the camera. It allows you several viewing options, and is easy to accidentally hit and turn the LCD screen "off."
Apr 27, 2008 | Canon PowerShot A640 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
