Question about ASUS P4P800-MX Motherboard
Computer keeps restarting
The computer will get to the windows xp screen then the monitor will go black and the system will restart. I have replaced the memory, harddrive and hdd cables. i think it is a problem with the motherboard. there are no cards on the board. i took off the only card which was the modem. i put a working hdd in from another computer and still the same problem. i also put the hdd from the bad system in another machine and no problems. put in memory from other system and still problem. the motherboard is an asus p4p800-mx.
    Top Expert:
  • ASUS Master
  • 76,846 Answers
Have had this very same problem, after many frustrating hours of tests replaced the motherboard and cured the problem.
Posted on Sep 03, 2009
Windows xp black screen problem
Use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Use system utility software like RegInOut after restarting windows.
Dec 31, 2011 | Microsoft Windows XP Professional
Monitor's resolution need to be increased, how?
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Aug 22, 2011 | Northgate MONNG7NSS 17" Flat Panel LCD...
I was trying to hook up my laptop (Dell Inspiron 2200)(windows xp) to my television. I managed to get the laptop to go to the tv screen, but when computer rebooted, I got a black screen and cannot get rid...
use the F8 button before windows starts. as the laptop show the manufacturer's screen. keep tapping it gently and fast until you get froted with the bootup options screen. Select whichever option reads the word "VGA" in it. Then it will boot into windows. Enter the multiple screen setup (could be hard given that screen could show all icons and windows big) and select proper settings. Restart the PC and ensure the options remain active.
Aug 31, 2009 | Dell Inspiron 2200 Notebook
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
One of collegues pc keeps restarting randomly. The page goes black and then it restarts and login window comes up. Cable all seems fine. It's an HP machine, Windows XP SP3, 2GB RAM, Interl Core 2 Duo...
Only 2 possible reasons seem to be there either. Pull out the RAM From it slots blow it properly and re-install the RAM. Get a third party software for monitoring system heat. Monitor it and if processor heat going above normal then install one more fan to it.
Jul 22, 2009 | Computers & Internet
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
New Monitor in my computer using a xp profesional
Restart your system and keep tapping the F8 Key as soon as you start the system. you should be at an advanced OS options menu, select SafeMode with VGA and proceed to logon to windows. Once in windows, right click on your desktop > properties > Settings > reduce settings to 800x600 > click OK > restart system. Now the display should be back on the monitor. Now read the manual to understand the highest supported resolution for this monitor + set the same as mentioned before on your system.
Aug 12, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
The HP monitor stop working with systemax windows xp
no vga input message means that the monitor is working fine, and the problem is probably your pc. check the cable connecting the monitor to the pc. if that is ok, you ma have to open up the pc and check some components, most likely the RAM
May 02, 2008 | Microsoft Windows XP Home Edition
ASUS P4P800-MX Motherboard Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
