Trying to use this on my mac and it will not read or write anything
SOURCE: I've just bought one of these for a Mac G4 running
You need to locate a piece of software called Patchburn - but I think that might be difficult now.
This particular vintage mac only worked with the drive that was in it. in order to use a different drive you had to patch the system so that the new drive would be recognised as a burner - that said, it should just work as a player/CD-ROM.
The later Macs didn't have this problem and you could stick a drive in and it would be recognised straight away as a burner. I recently put a LG drive (with lightscribe) into a G5 mac and it worked straight away as a burner/player but I did have to install the lightscribe software.
SOURCE: DVD rewriter wont install
yeah i have the right solution,
right click on my computer ----> select properties and in that select ---->hardware tab ----> advance and select----> device manager ------> select IDE ATA/ATAPI controllers (expand it ) and go to SECONDARY IDE CHANNEL right click select properties and in that go to advance and in that change tha transfer mode to PIO ONLY from DMA IF AVAILABLE(its default)
SOURCE: GSA-H55L problem
your dvd writer have warranty
so you contact LG customer care is better
you can use their free service warranty
SOURCE: Cannot back up DVDs on LG Super Multi 20x DVD rewriter
You definitely should call LG--your new gaget isn't working, and it is under warranty. Or try going to their website to see if they have any software upgrades--sounds like you have a bummer, and perhaps a reinstall from their website will do the trick.
