Question about Sharp AR-153E Copier
Sharpdesk Scanner only works with certain computers?
I have installed Sharpdesk on several machines where I work and it only seems to work correctly with certain machines. I have tried finding any similarities (programs, O/S, etc.) that could explain the problem but I'm at a loss. I've been trying to figure this out for weeks and i'm about to pull my hair out. Any ideas?
Had the same problem and discovered that the PC's that didn't work had Windows Firewall turned on. Turned it off and it worked. (Of course, you could also allow ScanDesk's port through if you want, rather than turning off the firewall completely.)
Posted on Oct 01, 2009
    Scholar:
  • 118 Answers
Chances are it's the configuration of SharpDesk that's in question here. SharpDesk is designed to work with a myriad of systems as a scan interface, but older versions (pre 3.2) can be buggy, especially with Adobe Acrobat/Reader below version 7.
What you should do is go to each PC with SharpDesk installed and launch the program, then go to the pulldown menu and click on 'Tools'. Next, highlight 'Product Configuration', then choose the sub-menu item 'Network Scanner Tool'.
Once the tool launches, click on the 'Scanners' tab. In the 'Known Scanners' window make sure the IP check-marked matches that of the copier you're scanning from. Once you've highlighted that IP address, click on the 'Auto Detect' button to the right.
This will send a command to the copier to confirm communications pathways and test them. Once that's completed, click on 'Apply' and you should be able to scan to that PC.
If this doesn't work, you may need to check and verify the actual scan setup entries on the copier's webpage. Launch your normal web browser and plug in the IP of the copier in the address line. If you get a security prompt it's 'admin' (all lower case) for the login name and 'Sharp' (capital 'S', all other letters lower case) for the password.
You'll need to go to 'Destination Management', then whatever setup option you're using (i.e. e-mail, ftp, desktop, etc.) and confirm the existing entries for the scan functions are correct.
Hope this helps!
Posted on Sep 04, 2009
  • 32 Answers
Sharpdesk is so designed and made for Sharp digital multifunction units and can be installed on any windows OS on most sharp brand.
Posted on Sep 05, 2009
My scanner quit working it says no scanner was detected. but it was working
I have a Xerox scanner that disappears. So far the only way to fix it is to uninstall and reinstall the drivers.
Apr 24, 2017 | Office Equipment & Supplies
Sharpdesk scanning problems
Seems like a driver problem. You might consider buying a new one, as they're really cheap and might cost you less than spending hours and hours trying to solve it ...
Jul 17, 2014 | Konica Minolta bizhub Office Equipment &...
Sharpdesk will not open
Uninstall then make sure you run the setup.exe as administrator.
Also, check to make sure the windows firewall has exceptions for Sharpdesk and the Network Scanner tool, and any other firewalls have the same. Skelton Business Equipment Houston Copiers
Mar 26, 2014 | Sharp Mx-2300n Copier Color Mx2300n...
Sharpdesk issues
I had this same issue. The problem was because the client was using an older version of Sharp Desk on Windows 7 machines. After uninstalling SD, I installed SD 3.3. No more issues.
Jan 23, 2012 | Sharp Office Equipment & Supplies
Serial number for AR-M207 Sharp Printer Scanner Fax
The sharpdesk ser # is located on the documentation that came with the installation disk.
Dec 29, 2009 | Sharp AR-M207 All-In-One Laser Printer
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
We have a new employee. How do I change the name on "image send" to the new employee?
I am assuming you have sharpdesk or network scanner tool installed on the computer you are wanting to send a scan to.
Click on start then programs and look for sharpdesk/network scanner tool and start the NST program. Once it is open/started you should be in the "profiles" tab and there should be some profiles listed (presumably the old employees name). Put a check mark next to the ones you want to delete and click delete. this will remove them from the copiers image send. Then create a new profile (add) with the new employees name and apply the changes. Restart the copier and the employees name should show up.
Mar 25, 2009 | Sharp AR-M355N Copier
Computers cannot find the Sharp Scanner on the network
Are you using Sharpdesk? first check the firewalls, allow the exception, if that is not it, then from network scanner tool profiles, Change the Port, I believe it defaults to port 4687 - or 4689? (this uses an FTP port,) Allow this port in the exceptions. If the network scanner tool is not running, your machine will not communicate with the PC.
Jan 20, 2009 | Sharp AR-BC260 Color Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
How to use the scanner sofware?
Here's the link to the user manual for the copier (it says ar122 and ar152 on the front, but it is the same manual, read it as if you had a AR 122E); http://www.tradenet.sharp.co.uk/files/Copier%2CPrinter%2CMFP/AR_Product/AR153EN/AR153EN57.pdf Check this link for basic info on Sharpdesk; http://www.sharpusa.com/products/applications/sharpdesk/1,2693,3-3,00.html If you open sharpdesk, select the help menu there should be "about sharpdesk" at the bottom - this should tell you which version of sharpdesk your office is running. Check this link for the user manuals for most versions of the Sharpdesk program; http://esupport.sharp.at/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=nl&ProdLine=34&SortOrder=DESC&OrderBy=Title&SearchString= Hope this helps, please ask again if you have any questions :)
Jul 05, 2007 | Sharp AR-153E Copier
Sharp AR-153E Copier Logo
1,747 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
