Dec 20, 2007
- Open the network system preference on each machine see
http://systemacs.com/OSXCheatSheet.pdf
For the iBook is the USB wireless adapter chosen as the shown network. If not select it.
For all questions below anything having to do with userid and password -- just tell me if the box is filled in or not, I do not want to know what is in the box nor do I want anyone else reading this to know. WEP or WPA passphrases or keys are also considered passwords in this case I only want to know if they are filled in not what the content is. - We will discuss the content and what to compare too later, if necessary.
What is in the boxes on the TCP/IP tab?
for the remaining tabs are there any boxes filled in?
if so excluding UserID's and Passwords (inc WEP and WPA) what is in the boxes?
For the iMac is the built-in ethernet adapter chosen as the shown network. If not select it.
Report this information back on a comment please.
They have not provided me the documentation on the adapter yet either. So I have no idea the steps to enable it specific to the Mac -- excluding those with the system preference network above.
A couple of items you did not move the iBook too far from the wireless router did you? Just in case try connecting from the same room and let me know what happens.
I would hold off on switching machines with the adapter for now but if you proceed consider the following:
Before switching the wireless to the other machine a good first step would be to get the iBook working on the wire first assuming it has an ethernet port -- then you will have one working machine in case of problems.
If you want to try the wireless on the other computer -- you need to know what software to install, if any. You will need to disconnect the wire -- or else you will not know if the wireless or wire is doing the work. It is doubtful the wireless will break the internet connection if you switch back to using a wire, but having the other machine as a backup is a good idea just in case.
