Question about Electro Brand Nostalgic Stereo CD Music System Shelf System
I am unsure how to insert the cassette into the side of the unit. I am afraid to force it - the manual does not indicate any particular instructions. Help would be appreciated.
  • 67 Answers
This photo should help you.
Posted on Sep 04, 2009
  • Brenda DWilliams Nov 08, 2011
    what does this mean cassett has to play from xterior speakers,,,,I am over 60 be kind !!!
SANYO FXCD-500 has CD Stuck inside player. Radio & Cassette Still Work. It is Still in Dash of my Toyota 4x4 Pickup. Besides taking unit out of Dash??? Any Suggestions??
Sanyo FXCD-500 Operating Instructions Manual - ManualsLib
www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
Mar 30, 2015 | Toyota Cars & Trucks
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Nakamichi480dualcassettedeck won't open. May have put cassette in wrong way. Is there a fix?
Michael, What do you mean with may have put it in wrong? Up side down? because every cassette has 2 sides. It is almost impossible to put a cassette in, up side down. Or you must have used enormous force and then opening would not have much sense, because you must have damaged a lot.
If you want a manual, you could try this site, but you have to sign in, for a user and or service manual. Nakamichi 480 Manual Two Head Stereo Cassette Deck HiFi Engine
Dec 02, 2014 | Audio Players & Recorders
Cassette mate
The product arrived with an instruction manual. I followed the instructions, installed the included software, and then was unable to get the product to work as my PC (Windows 7) did not seem to recognize the device. I tried several USB ports to no avail. I emailed the seller and promptly received an email with different instructions. Although the software version on the installation CD was different from that referenced in the instructions, I was able to install and finally got the device to work as needed. The problem is that there are two programs on the installation CD and one (cassettemate) appears not to function, while the other (audacity) is what is needed. This is not indicated in the instructions that come with the device.Close cassette mate window and open audacity press play in the cassette player and press recording button in audacity program.
Jun 23, 2013 | EzCap Tape Converter - Tape to PC Super...
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
JVC12 DISC CHANGER CH-X550 jammed
I would pull off cover, unscrew and remove top carriage of tray and remove your disc. While your at it you should take cotton swab and dip it in rubbing alcohol and clean the laser lens. Then reinstall carriage and top cover and try using it again.
Jun 22, 2009 | JVC AM FM CD DET FACE CAR STEREO
Tape cover on unit is jammed
Don't force it, most likely the trouble is the capstan belt and U need to drive the mechanism foreword so the play mode can be released and the door will open but this will happen all the time till U get the belt replaced!
Dave, Electronic Doctors Email eledocs@hotmail.com
Apr 01, 2009 | Sony Audio Players & Recorders
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Cassette stuck
I have the same problem eject cassette stuck on my brothers camera he gave it to me to bring home to try and fix for him how-ever not before his son tried to force it and damaged some of the casing that holds the cassette. I straighten it all out and then found that a very small spring at the back of the camera had come off which was stopping it from ejecting. Once I lifted this spring and hooked it back on that it now ejects no worries at all..
May 01, 2007 | Canon MVX250I Mini DV Digital Camcorder
Electro Brand Nostalgic Stereo CD Music System Shelf System Logo
100 people viewed this question
Top Electro Brand Audio Players & Recorders Experts
Ben Armstrong
RobertFonner
RobertFonner
Are you an Electro Brand Audio Player and Recorder Expert? Answer questions, earn points and help others
