Question about Maytag Washing Machines
Maytag Centennial Washer on Super Plus. When washing starts to fill up between tub and basket until water leaks from tub past the tub ring. Smaller water cycles it works fine.
    Top Expert:
  • Maytag Master
  • 10,321 Answers
Possible bad tub seal
Posted on Oct 10, 2019
SOURCE:
Washer_tech
  • 164 Answers
SOURCE: Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
  • 297 Answers
SOURCE: Normal wash cycle- tub fills (?), then comes a loud hummmm and nothing happens. I noticed water level didn't reach heater coil and added water until limiter switch clicked. Still just a loud hummmm. M
You are an expert enough reading this. But with a terrible complicated dishwasher. First clear the waterlevel problem.
Rest is a result. You do not need me, join us. Next time buy something more plain.
Posted on Apr 16, 2009
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Posted on May 03, 2013
Have necklace stuck between tub and basket of Maytag Centennial low water washer
Visit http://www.maytag.com/manuals/ and type in the model number to find documentation for your washer. Maytag also has a help line at 1-800-253-1301.
Apr 19, 2014 | Maytag Washing Machines
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Gertrno water will go in the tub
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 09, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Gets out balance almost all the time .
check in tub, plastic ring at top, not the bright white top one but the off-white one underneath. gap between rings should be even all way around. push down on it, if it seems to click into place then it has come unhooked, rubbed against the upper ring, worn a hole in itself and filled with water. Do you get little granules of plastic in the clothes? Machine will not balance like that even empty. Replace the ring (pain in the...)
Mar 14, 2010 | Maytag Centennial 3.2 cu. ft. SuperSize...
I just purchased a Maytag Centennial washer ..it will NOT fill the tub completely with hot water. I have been told that is an 'EPA' spec .. is there anyway to over-ride or go around the sensor that is...
There may be a water level/pressure switch that will accommodate your washer. However, if you install it, I am certain that during the normal warranty period, if you need service, the manufacturer will probably void your warranty if they notice the alteration!
Contact an appliance service company.
Feb 19, 2010 | Maytag Centennial 3.2 cu. ft. SuperSize...
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
