Question about Maytag Dishwashers
Maytag WU1000 Series 2 has no power, is there a fuse in the door or on the lower unit? Any other suggestion?
    President:
  • 632 Answers
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable.
  5. Try by-passing the switch. If the unit powers on replace switch completely.
  6. Check the timer or selector switch. replace if defective.
Posted on Sep 04, 2009
Maytag 5000 series washer control locked light is on and washer wont turn on
1. try unplugging or flipping circuit breaker, wait 10 secs, hold in power/on button for 5 secs, plug back in and see if it resets.
or
2. try tapping on door lock position on front of unit and see if it unlocks unit(lock stuck). hit it hard with palm, but not enough to dent or damage
good luck
Sep 24, 2016 | Maytag Washing Machines
Maytag 5000 Series Washer won't start. Door lock light won't come on. No function will start.
Hi Al....sounds like you checked just about everything.
However.... I am going to throw one last check your way.
Blown fuse or tripped circuit breaker. Good luck.
Regards,
Denis
Oct 21, 2014 | Washing Machines
Maytag maxima codes F06 and E02: Tried doing a spin/rinse/drain on an empty machine. Timer seems tpo be working but cannot hear water filling or barell spin. tried to shut off and door is now locked.
see this causes and fix it. God bless you
POWER/CANCEL press for to cancel the error codes.
First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.+fuse thermal +c.breaker
Oct 16, 2012 | Maytag Maxima EcoConserve Series MHW6000X...
Maytag quiet series 3000 lights do not light up. Unit has power and door switch is working correctly
maytag 3000 washer will not lite up or power on outlet was checked it works.
Aug 07, 2012 | Maytag Dishwashers
Where is the thermal fuse located at?
on the heater element tubes left side,you need to unplug the unit,then remove 4 screws holding the door on,2 on left 2 on right side,then remove and set door aside,then grasp left and right upper sides of front panel and pull toward you lift up and away from unit and set aside,now you can look in at the lower right side of the interior of the unit and see the fuse located just below the drum
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Quiet Series 300 dishwasher that is approximately 2 years old. It has been working fine up until now. It has no power at all, no lights etc. I have checked all the power breakers and...
This dishwasher does not have an internal fuse in it unfortunately. Check for power to the dishwasher and if it definitely has 120 volts you need to order and replace the touch control at the top of your door on the dishwasher. This part common fails and cuts power to the entire unit.
http://www.appliancerepairlesson.com/
Good luck
Mar 02, 2011 | Maytag Dishwasher
I have power at the plug, but the electric dryer will not turn on. Is there a fuse in this unit to stop the power, this is a maytag med5700tq
Good day,
No fuse, sorry.
Make sure there is 230 volts at the dryer. (careful, 230 kills).
If so unplug the machine
1. The door switch is bad, you will need a vom meter to test it for continuity. Power goes to the door switch first.
2. Push to start switch, if your model has a separate one. if not...
3. Possible bad timer contacts not sending power to the motor.
4.Open circuit in the motor.
Feb 09, 2010 | Maytag Dryers
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Aug 21, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwasher door gasket replacement
hi alan, the tool that works for me is a pair of 90 degree curved needle nose pliers (mine are a sears product). also, i soak the gasket in hot water for five minutes to soften it up and sparingly apply soap dish detergent to the tabs to give them help in sliding through. sorry i dont have a pic of the tool for you.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
75 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
