Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Unit is shaking off the ground when going into final spin mode
The Frigidaire stacked unit washes fine throughout the wash cycle and then starts rattling and almost teetering over. They just delivered the unit and this is the first time we have done a load of laundry.
Please help!
  • 41 Answers
It is unbalanced, you must contact your supplier and have him fit it properly. do not do anything or you will invalidate any gaurantees
Posted on Sep 03, 2009
Will not wash
motherboard of the unit may be defective
Dec 25, 2013 | Frigidaire FAFW3574KA Front Load Washer
Frigidaire front loading washing machine will not do final spin
If you cannot manually turn the tub when it is off, and not in use, then the motor and transmission is possibly seized. If you can turn it with no issue or noise, then the control is not communicating correctly to the unit.
Dec 28, 2012 | Frigidaire Washing Machines
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Spin Cycle Kenmore 44052
Possible that the control unit is malfunctioning. You can remove the unit and reset all connections, check for visible track failure or moisture in the unit, if so use a heater to warm off all moisture as it can cause malfunctioning. Finally check the wires to see if there is any that this loose or snapped.
Sep 03, 2012 | Kenmore 98702 Stacked Washer/Dryer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
