Question about TruTech T160-CD Personal CD Player
Turning off T160-CD
I don't understand how to turn this unit off. I do not have a manual for the T160-CD, but it seems the only way to shut it down is to remove the batteries...quite inconvenient.
Pc comes on automatically when plugged in
it mostly happens when pc is not shut down properly
mostly when we turn off main plug before pc is shut down
Jun 26, 2014 | Acer American Corporation Aspire T160...
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I have a Compaq (CQ61Z) laptop stuck in sleep mode. We have tried shutting it down (manual override by holding the power button) unplugging it and waiting etc. Nothing seems to work. Any hints?
Anytime you use the sleep mode, your battery is working to save your information. Your battery may be drained, depending on how long your computer has been asleep?
Try taking your battery out and use your power adapter only and just press the power key...don't hold it down, just press it like your turning it on.
This should fix your problem! When you get back your power, you need to go into your power setting and set your setting to 'Never', this way, you don't have this problem again.
If you need further assistance, don't hesitate to reply back to me.
Kind regards!
Sep 13, 2011 | HP Pavilion a1710n (RK573AA#ABA) PC...
My infocus t160 turns on and after a minute it shuts down and the lamp and temp (signal) is on
The fault may be the cooling fan, it may have dtopped working and caused the unit to shut down.
Aug 25, 2011 | Computers & Internet
Tray for cd won't open and it says "mechaical error." Unlike in the past there seems to be nothing stuck or askew inside. I left unit on overnight and tray was apparently open because I saw it...
you need to open the cover of your component and have access to the mechanical system of the CD. The timing gears might got dislocated and you need to manually adjust them.check also if there are belts that are broken replace them.
Mar 07, 2011 | Yamaha GX-505 CD Shelf System
Netvista won't start up
I can understand your issue. Well it seems the issue is based on Motherboard or Memory Card.
But we have to check all the possible solutions.
1) At first when you turn on the computer are u getting any beep sound.
If the beep sound is lengthy then i'm sure the memory card is gone bad.
2)You can try by swapping the memory card in different slot and try turning it on.
3) Once you isolated as memory is not the problem, then go ahead and take out the battery (like a COIN) inside the board. Then try turning on.
4) If still the same problem, please disconnect all the cable from the board (Includes HDD, CD-ROM, FDD) and check for the flea power led which is on the board.
5) If the LED is lit on, then no issues with motherboard.
6) Finally you have to check with SMPS.
If all the above 5 condition is true, then you have to replace SMPS (Switched Mode Power Supply).
If you have any constraints please revert..
Jan 11, 2010 | IBM NetVista PC Desktop
FM or AM
You may have to manually set the preset stations on the unit itself. Read the user manual.
Dec 20, 2007 | Sharp CD-XP120 CD Shelf System
Unit turns on, then clicks off with a "protect" message
You have a bad speaker on this unit or the audio output circuit is in need of repair. Try to disconnect all of the speakers and then turn on the unit. If it still stays in protect, you will need to have this unit serviced, unless you understand how these solid state circuits work. If the unit does come on without the speakers, turn off the unit and add one speaker at a time until the unit will not turn on. Disconnect that speaker and have it checked out or have the wiring checked out. Good Luck
Jul 14, 2007 | JVC FS-G5 CD Shelf System
37 people viewed this question
Top TruTech Audio Players & Recorders Experts
David Payne
David Payne
Tom Chichester
Are you a TruTech Audio Player and Recorder Expert? Answer questions, earn points and help others
