Question about Sport & Outdoor - Others
I have a 1995 Viking Pop up camper. I blew a fuse repairing the outside light switch. After replacing the fuse, all lights, including inside are still not working. All power outlets work, just no lights.
  • 534 Answers
I would double check the fuse then check for ground. It sounds as if you may have a ground disconnected since only the lights aren't working. You can do this to check to see if it is a ground problem but your switch will have to have a grounding wire currently hooked up to it. You can take the green grounding wire and place it on the terminal where the white wire is connected. Once you turn on the power switch on the power to the lights and see if they work at this time. If so, You have a grounding problem. Good luck on your repairs
Dave
Posted on Sep 03, 2009
Westinghouse range hood wrf900cs light blew, light globes replaced but lights still not working
I had the same problem. An audible pop and the lights stopped. Fans still works, light bulb filaments appear intact.
My problem was that a short piece of the copper on the printed circuit board, inside the switch housing, had vaporized as if it were a fuse. I soldered a bridge of copper wire across the small 5mm gap and all was working again.
Access the switch compartment by removing the filters, undo a couple of retaining screws to remove switch unit.
Make sure the electricity to the unit is Off/unplugged before proceeding!!!
Switch unit cover has 4 screws holding it on. Once inside the unit, trace the wire (mine was grey colour) from the light switch to the small printed circuit board. The copper printed circuit link to the connector had gone...no sign of burning, just gooone!
Solder a bridge of copper wire across the gap and reassemble switch unit to test.
....send beer donations to me in qld...cheers!!!
Jun 29, 2012 | Kitchen Ranges
My Husqvarna Rose is dead. My husband tried to replace the bulb and it was the wrong one and it wont turn on at all. IS this too a fuse. Where is the fuse on these machines
You can check inside the power supply unit for a fuse, but I think he probably blew a voltage regulator and the power supply will need to be replaced. Contact an authorized Husqvarna Viking repair center.
Dec 13, 2010 | Husqvarna Viking 1
I have a coleman cheyenne 2000 pop up camper and none of the lights will turn on to include the carbon monoxide alarm. All of the outlets work fine. We checked the fuzes and flipped the switch. We also...
when towing my camper it seems my running lights do not stay on andmy brake lights and turn signals do not work properly. I can giggle the harness wires and everything works.
Jul 08, 2010 | Camco Battery Fridge Refridgerator Alarm...
Lights wont turn on
There are some fuses for that,if they are not blown,replace the headlight switch
Apr 11, 2010 | 1995 Ford F350
Multiple sparks when igniting one burner
have a 1997 model 2470 viking pop up camper , has a shower in stalled where does the used water come out ??
Jun 19, 2009 | Viking VGIC305-4B Gas Kitchen Range
Pop up Camper will not raise up when cranked
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
Jun 04, 2009 | Arc'Teryx Rock & Ice Climbing
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
95 Geo Tracker Dash Lights out?
replace the blow fuse
above left knee, fuse panel there.
1 is blown.
your amp was shorted, it blew and took out what oem wiring they hacked into .
bad installation.
Sep 09, 2008 | 1995 Geo Tracker
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
