Question about Linksys Wireless-G WRT54G Router
I connect to my Wireless Network with "Limited Access" ?? I have been connected to 4 wireless machines for two weeks now I can't connect ??
    Problem Solver:
  • 8 Answers
Check the network your in. execute "ipconfig" command in your machine or check your network configuration. prob you'll get something that is like 192.168.x.x. if so and you have restarted your equipement (PC and router) check your network connection to the internet. if you dont have it, that message will never disapear.
Posted on Sep 03, 2009
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Wireless network limited access
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Mar 23, 2012 | D-Link Computers & Internet
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
My wireless radio is off, and it says my connection has limited to or no connectivity, but when i look at the signal strength it says very good to excellent..My computer has been like this for a few weeks....
To fix the issue, please perform the below steps:
1. Right click on My Computer icon and go to Manage.  2. Go to Services then go to Service and Applications.  3. Double click on Wireless Zero Configuration.  4. Change the Start Up Type to Automatic and click on Apply  5. Click on Start and press OK to close the window.  6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 7. Right-click on the wireless Network Connection icon and select 'Properties'.  8. Go to the 'Wireless Networks' tab .  9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 2. Right-click on the wireless Network Connection icon and select 'Properties'.  3. Click on the 'wireless network' tab. 4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK. 5. Right-click on the wireless Network Connection icon and select 'View Available Networks'. 6. Look for the SSID (aka Network Name) of the Wireless router or access point.  4. Highlight thee SSID from the list that you want to connect to.  5. Type the security Key here and click on the 'Connect' button.  6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Jan 24, 2010 | IBM (31P8301-IBU) 802.11b Wireless Adapter
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
We've had a laptop connected to our d-link wireless router for the last few weeks with no problem. Yesterday we lost the laptop internet connection. When we go to diagnose the problem, it shows that the...
Try resetting your wireless router first, then make sure that the network you are connecting to is yours and not another nearby wireless signal (I live in an area that's polluted with wireless signals and sometimes a neighbor's signal will be stronger than mine, so it will try to connect to theirs). If that doesn't work then go to your Network and Sharing Center and choose the setup a network connection option. You'll have to manually enter your info again but it should work fine.
Sep 15, 2009 | D-Link DIR-615 Wireless Router
Unable to connect to wireless network
Re-Enter your wireless key correctly is normally what thats means
Mar 15, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
Cannot connect
If you're trying to connect wirelessly, you probably need to disconnect from the wireless network in the wireless network manager and reconnect. This will force you to re-type the wireless access key. If you have the correct wireless key, it should connect and give you an IP.
If you're connecting using a network cable, your network connection settings may need to be change so that your computer will get an IP address automatically.
Jan 31, 2009 | Belkin (F5D7230-4) Router (587009)
Home wireless network
Most wireless1.gif networks are setup as infrastructure networks, meaning all communication is to/from a wireless access1.gif point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking1.gif refered to as ad hoc -- in this version of wireless networking every wireless adapter1.gif can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's1.gif wirelessly without a wireless router1.gif or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Linksys Wireless-G Broadband Router
Compaq n6120 - can't connect wireless
Most wireless networks are setup as infrastructure networks, meaning all communication is to/from a wireless access point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking refered to as ad hoc -- in this version of wireless networking every wireless adapter can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's wirelessly without a wireless router or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Dell Inspiron 6400 Notebook
Linksys Wireless-G WRT54G Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
