Question about Dometic RM2852 Refrigerator
The freezer is cold not the refrigerator. when plugged into 110 v
    Problem Solver:
  • 5 Answers
Well I sure hope it is plugged into the 110V, otherwise it wouldn't cool at all!
If your freezer is working normally (cooling properly, evap fan is running) and your fridge section not, then you have a damper problem, not opening or opening enough to let air circulate to your refrigerator.
Posted on Sep 04, 2009
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Our freezer is not making Ice and the refrigerator is not cold
have oiyu ried to thaw it out then plus it back in? also is there anything that could be blocking the air at all? The easiest way to thaw a freezer is to take a shop vac and turn the air around and blow it on the coils to thaw out the ice. go ahead and make sure t=hat its cpompletely thawed out them turn back on and check the air flow afrom the fan after its ran a little bit. Don't rae until your problem has been resolved then rate the best solutions please. Thanks for using FixYa.
Posted on Jan 01, 2009
  • 942 Answers
SOURCE: Refrigerator is not getting cold.
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Posted on Mar 31, 2010
heatman101
  • 43501 Answers
SOURCE: Refrigerator is a Cold Spot Model
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Samsung rf217acrs freezer is not freezing
would check ur freezer thermistors and cold control thermostat as well as air flow damper vent
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Aug 14, 2014 | Samsung RF217ACRS Stainless Steel 20 Cu....
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
I had leaking from the freezer. Cleaned the air intake and it was plugged with dust.Turned it back on and noticed more ice buildup at drainhole. The coils at the bottom of the freezer coils were red hot. I...
It sounds like your freezer was going through the automatic defrost cycle but the water couldn't go through the plugged drain. Clean the drain so the water can go out.
The refrigerator side gets cold by the cold air that comes from the freezer, so in order to have a cold refrigerator you need a cold freezer.
After you have cleaned the drain, turn all back to original settings.
Hope this helped, let me know.
Thank's for using Fix-Ya
Jan 10, 2011 | Refrigerators
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Fridge not getting cold
refrigerator hts 16 hbfrww is not getting cold but the freezer works well, ive defrosted the refrigerator plugged it back in it worked for about a week then stoped getting cold again.
Jun 16, 2009 | Frigidaire FRT18P6BS Top Freezer...
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Frigidaire gallery frigde is not cooling
If you never hear fan running in freezer, this could be the case. How old is this unit? Newer ones have a electronic defrost board. Older ones have a mechanical defrost timer.
If the fan in the freezer is on, and not getting cold...could be a compressor, or the relay/overload on the compressor. You'll need to check for voltage at the 2 wires at compressor. Should have about 110 volts when the freezer fan is on. If you have 110, Unplug unit and remove relay/ overload from compressor and shake it. If it rattles, you probably need the relay/overload. If this unit is only a few years old, it may be a compressor. We see these fail on these. Does it make a load hum for less than a minute followed by a click. And then after a bit, does it again. This is usually a bad compressor.
Nov 14, 2007 | Frigidaire FRS266ZDSB Side by Side...
Dometic RM2852 Refrigerator Logo
269 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
