Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hayward heater attached to a 2PSI natural gas regulator
The main gas meter and input have been checked and are correct. I have had the Hayward heater checked 3 times and it is set perfect. The issue is probably the gas regulator at the heater. There is a 4lb regulator at the meter - which is correct. The 2psi regulator at the hayward heater tends to "purge" after I finally get it lit. It often "IF" codes which means fails to ignite. You can smell gas - but it won't light. Last resort is to change out the regulator.
  • John Prohaska
    John Prohaska May 11, 2010
    What elevation are you installing this heater at? Most Haywards are rated for inlet gas pressures measured in inches water column, not PSI. Inches water column are far less than even 1 psi.
    Champion:
  • 246 Answers
Or change the heater. have you clean the burners
Posted on Sep 11, 2009
I have Hayward H400IDL2 heater I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater blower comes
Good Day, missed your post for a few days. #1 & #2 fuses are on the high voltage side. This could mean a problem with incoming voltage or a bad fuse or main circuit board. Call our tech line at 908 355-7996. I have attached a link to the manual. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
I have 2Psi inlet pressure so if I don't use regulator pilot is working but huge flam. But when I put regulator in (3
Hi there.
Your maxitrol regulator specification is correct for natural gas use, the pressusre setting may be in minimum (3"wc) that's why the fryer does not fire-up or it may also be clogged.
Check also if the spring is sitting properly on top of the plunger.
Regards.
Jun 24, 2012 | Frymaster Dean SR42G Deep Fryer
Can an H150PI pool heater be converted from propane to natural gas
On this heater, the conversion may be a kit that replaces all the orifices. In any case if you call Hayward technical support they should be able to provide the correct solution. I hope this helps.
Jul 27, 2011 | Hayward H-series Electronic Gas Pool...
I have a gas leak
If the valve "in the heater" you are talking about is the main gas valve, check the regulator, which should be before the main gas valve.
Jun 20, 2010 | Hayward 2001 Series Millivolt Gas Pool...
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. dbkohl@prodigy.net 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward H400FDN won't stay lit
It is probably not sensing flame. You either have a clogged orifice underneath the flame sensor and you probably need to have the gas pressure assessed, meter size and gas valve pressure adjustment. These heaters need 2" wc of gas pressure.
Apr 17, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
332 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
