Washing machine will not spin.
I recently changed the drive coupling, however the tub will not spin. It makes a "clanking" sound. The machine will agitate and drain. I assume the problem is in the transmission?
    President:
  • 744 Answers
Hello, I am going to risk getting a bad rating here but I'm one of those that hates passing by a question because I am likely to get a bad rating. No spin and clacking noise is the coupling, Pull the motor off and take another look at the coupling..I'm willing to bet its bad again. If the coupling is bad again replace it and watch the machine over the next couple of months..If it breaks again your transmission is going bad and your going to have to buy a new washer. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Sep 04, 2009
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Samsung washer WF409 is making a clanking noise at spin cycle
CHECK THE TUBS AND MAKE SURE YOU HAVE NOTHING THAT FELL OUT OF A POCKET ALSO CHECK BETWEEN THE BOOT AND TUBS.OTHERWISE CALL FOR SERVICE THATS WHAT WARRENTYS ARE FOR! GOOD LUCK!
Jan 16, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
WHIRLPOOL 5125 LOUND NOISE
I take it you are refering to the AWM5125
The sound you hear are the bearings on their way out. You will need a replacement rear tub half
Jan 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Agatiator
you broke a drive coupling
May 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing maching 25862
yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Dec 21, 2006 | Kenmore 25862 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
