Question about Dell Inspiron 6000 Notebook
Had to reinstall my OS, now I can't use the internet
Had to reinstall my OS, now I don't have networking, it will connect to the router but won't get a default gateway address... I can't surf the internet. it's a dell inspiron 6000
I downloaded the Broadcom network drivers and the Intel PRO wireless drivers from the dell website and installed them. that part works, it connects to the router fine.
when you run ipconfig it says "media disconnected" under network controller and there's no IP address or default gateway.
other computers on that router work fine
    President:
  • 2,600 Answers
I'm going to suggest something simpler for you to try...may work, may not work....Go to start > Run > type "msconfig" in the box and hit enter. When the window opens make sure the computer is on NORMAL startup. If it is good, close window and let the computer reboot. When it reboots and the DELL spkash screen shows strike the F8 key repeatedly until you see a screen filled with startup options. Scroll to "Safe mode with networking" and select that, hit enter and let the system boot. when it boots completely, check if you can get online...if youcan, browse around a bit a check a few different sites. If you can, then reboot the computer back to normal windows start up and try to get online.
Posted on Sep 03, 2009
    President:
  • 3,278 Answers
Be certain that you have downloaded the correct drivers. Find your hardware by booting with F2 then view Devicesviewting!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p {mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here's the link for your Inspiron:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=INS_PNT_6000
Hope this helps
  • NinaE Sep 03, 2009
    Oooh ... not certain what happened, but that first line should read:
Internet won't connect
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima
Apr 19, 2013 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
My Nintendo won't connect to the internet
Make sure there aren't any firewalls on your network. Try standing closer to the router when you try to connect. If these don't help you should contact nintendo customer support.
Sep 17, 2011 | Nintendo Dsi Pink Console
I hav a Dell inspiron 15 laptop and i have taken wired internet connection. but somehow my lancard has stop working and i am not able to access internet. can you please tell me some alternative to lan...
you can do a quick troubleshooting on the laptop.
1. used another network cable and check that no pins are broken on the laptop.
2. go to device manager and remove the network adapter and reinstall it.
if this don't work. if you have a wireless router, you can connect to the internet over the wireless network adapter on the laptop.
good luck!!
Aug 31, 2011 | Dell Ethernet Card Network Adapter
I try to connect to the internet using a laptop with an OS of ubuntu but currently i cannot connect to the internet. i connect to the internet only once but after 3 days it doesn't work again. i try to...
After you install ubuntu make sure that you click onto the two computers icon, next to the clock, in the top right corner of the screen and select enable networking. Also make sure the internet is hooked up to the computer before you turn on the computer that will help.
Oct 05, 2009 | Computers & Internet
Hello!After reinstalling WindowsXP on my computer (Had problems with viruses) can not connect to the Internet. O2 Installation CD says FAILED NETWORK ADAPTER. When selecting Control Panel and then Network...
I would check out the Internet for the updated driver for the NIC in the suspect machine, download it on another machice, copy over with flash disk. Remove the driver, install the new driver, **** down, reboot. If there is nothing physically wrong with the machine and you just re-installed the OS, sounds like you have a corrupted device driver for you NIC.
Sep 19, 2009 | Computers & Internet
Cannot connect to internet.
Since better than half of my customers use a Cable modem and I sell Netgear routers, this ought to be a piece of cake :-)
It sounds like one of your computers is working fine, and the one you reformatted doesn't. Is it Vista and did you get the drivers for the network card? Whovever reinstalled the OS should have done the drivers, but if they didin't, you'll probably have to go to the computer maker's web site and get them for your particular machine.
It's fairly easy to tell, because if you plug a cable into the network card and it either doesn't light up or is not detected, you don't have drivers or you have other issues. If you somehow do, then you can click on the Control Panel and Network and see the LAN card. It will either be enabled, disabled, or not there.
Once you get it to where you can see the network, now you can go about configuring the connection. I'm betting on missing drivers, but if you have any more questions, feel free to comment back.
Carl
Dec 06, 2008 | NetGear WGR614 Router
I have receintly bought a dlink wireless notebook adapter so i could set up my wireless wifi network at home to connect my compaq presario 900 to from a PC. I have installed everything and im getting a...
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks?
I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS.
Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again.
Hope this helps.
Jun 21, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
130 people viewed this question
Alun Cox
