Question about HP Officejet Pro 850 InkJet Printer
Quickbooks 2007 pro wont print to HP Officejet Pro 8500
When I try to print from quickbooks to my HP Officejet Pro 8500 it won't work. It ques up the print job for just a second or two and then disapears as if it printed. It will print to the fax. I can print out of every application I have except Quickbooks.
New hp 6500 officejet printer, cannot print checks from quickbooks pro
This is actually a quick books issue that they blame on the printers
here are the follwing steps to resolve the issue
Quick Books (2009) qbprint.qbp file change
doc&settings\allusers\appdata\inuit\quickbooks
rename above mentioned file to qbprint.old
if its an erlier version of quickbooks ie. 2006, the file path is then: doc&settings\programfiles\inuit\quickbooks then look for the file and rename it
Here is the website from intuit that acknowledges the issue
http://support.quickbooks.intuit.com/support/Pages/KnowledgeBaseArticle/1006446
Apr 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Quickbooks forms will not print on newly installed HP 6500
I deleted the qbprint.qbp file and that fixed it for me. Aggravating regardless.
Feb 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My HP 8500 stopped printing my Quickbooks 2009 checks. It worked fine for about 5 months and then stopped. I installed updates for both Windows and QB 2009 and reinstalled the HP drivers for my printer but...
click on start go to control panel. go to pritners. click on add a printer option on top of window. then add a local pritner. add deskjet 990c drivers use existing ports
Dec 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Quickbooks Pro 2007 Printing Blank Invoices
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
If the above are set correctly, go to HP's website and download the latest driver for your printer.
Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Jun 19, 2009 | Office Equipment & Supplies
Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Quickbooks quits when I try to print a previous reconciliation
You need to run the file in a Premier Version. Premier Version is the only version that access the previous reconciliation.
www.cpahispano.com
Jan 21, 2009 | Intuit QuickBooks Pro 2007 Full Version...
HP Officejet Pro 850 InkJet Printer Logo
464 people viewed this question
Seeker5211
Seeker5211
