Question about Sony Playstation 3 (PS3) Console
Hi ps3 stopted 3days ago ,it just keeps going 2
Hi ps3 stopted 3days ago ,it just keeps going 2 standby when yaturn it on blue light flashes on then goes 2 red standby again thanks ,
    Problem Solver:
  • 12 Answers
You need to send it to sony. or try to turn the main power switch off in the back. and unplug it from the back for 30 or more minutes. then try to plug it back in the. hit the main power switch in the back on. and try to turn it on then
Posted on Sep 04, 2009
    Problem Solver:
  • 5 Answers
Hardware failure need to send back to sony if still under warrenty they will not charge you if not it cost $150 and you need to set it up with sony support.
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
I have a ps4, when I turn it on the blue light will come on and then it'll go to the white one and there is no image on the t.v. even the homepage on the ps4 won't even show. Anyone know why?
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Jul 21, 2015 | PS4 Video Game Consoles & Games
When I turn on the PS3 it makes loud driver noise and the blue /green lights come on but after 30 seconds it beeps 3 times and flashes red. There is no orange or yellow flash. Someone suggested taking out...
hello have you tried to reset it.while in standby mode press and hold the power button you hear 1 bleep then 2 short bleeps release the power button this should reset the ps3 make sure you've got it connected to the tv screen hope this helps
regards
shaun
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Blue wavy line but no profiles to select
Alright mate, Had the same problem as you and my ps3 is up and running now. What you need to do are the following steps:
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
HOW DO I PAIR MY PS3 AND JABRA?
Make sure the headset is off and there are no flashing lights. On ps3 go to settings and look around cuz i cant remeber were it is at but look for manage devises or manage blue tooth devices something like that. You will select that and it will ask you if you want to search for devices. WAIT! First you need to put your headset in pairing mode. Hold down the side button (the one that flashes blue when it is on) and you will see it turn on and flash. DO NOT LET GO OF THE BUTTON!! KEEP IT HELD DOWN UNTIL THE LIGHT STAYS BLUE, NO FLASHING. you are now in pairing mode! Select search for bluetooth devices on your ps3 and it will begin scanning. keep your headset close to your ps3. When your ps3 finds it, it will ask for a code. Enter 0000. Thats it! ENJOY!
Feb 01, 2009 | Jabra BT125 Headset
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony bravia 46''
It sounds like it is defective, you have warranty call for service!
Jun 13, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony Playstation 3 (PS3) Console Logo
103 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
