Question about Humminbird Boating
I have a Hummingbird Matrix 17 fishing system. There is power to the unit, but it will not power on.
  • 5,537 Answers
Did you check the ground side of the connection? If that checks out there should be a fuse in the unit. You should look at the manual if you have it. If this unit is new to you and the boat sometimes the keypads require you to hold the "on" button in for a bit of time to power up.
Another possibility is the contrast controls are turned to the extreme and you are actually working, but dimmed out. You might want to unplug the transducer and see if the screen does anything.
You would need better testing equipment than the average person has to check frequencies. A radio shop may be able to help if you can not exchange this nonworking unit.
Posted on Sep 03, 2009
My hummingbird 175 does not show fish contacts
Obviously your hummingbird has stopped humming.
Check the most obvious things first. Power to the unit. Correct voltage at unit (no volt drop). Does the main box power up and appear to function OK. Then Check the Transponder connections. Clean with contact cleaner or methylated spirits & dry. Check for transponder cable damage. Try connecting a replacement transponder. Swapping parts to a certain what is working and what isn't. If you don't have parts then it will have to go to a dealer that does.
Good Luck
Jul 22, 2014 | Boating
Sunspot on screen humminbird matrix 27 can it fix ?
No, typically with led matrix screens, it is near impossible to find someone to replace screen for cheaper than new unit. Same goes for tvs and computers, etc. Also, and not to be rude but rather if you are faced with buying another unit, do not buy Hummingbird. They are a very cheap quality for not much less money. Best bet will be either Furuno or Garmin. Good luck!
May 14, 2014 | Humminbird Matrix 12 Fishing System
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
Need navionics mmc card for humminbird matrix 67
looking for mmc gold ma card for matrix 67 hummingbird unit one with mas of east coast and bays... and one blank for down loading soft ware. thanks bobbloss@gmail.com
Sep 15, 2011 | Humminbird Navionics HotMaps Classic -...
Screen shows images on fish instead of arches
Most sonars have a setting for FISH ID, on or off.. Not sure on the type of unit you have, so hope that helps. I've seen where hummingbird fishing buddy only have fish images and not arches...
Mar 02, 2010 | Boating
When powering up[on land] it says transducer not connected,checked cable and connections.It use to work maybe went bad? Humminbird Matrix 10
Disconnect cable from back of unit clean the pin connections on the unit and on the cable. If rusty clean with Corrosion X are WD
IF it doesnt work replace cable Jim OMC Retired Mech
Jul 05, 2009 | Humminbird Matrix 12 Fishing System
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
Boating Logo
155 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
