Question about Sanyo DS25390 TV
I have the same problem.
One horizontal line across the center of the screen. It was intermitent at first but it is constant now. I believe I could easily fix this problem myself if I had a schematic. Does anyone know where I can get a free schematic for this model?
The fuse in my tv keep blowing, how can i fix this
Posted on Sep 03, 2009
Horizental line center of the screen
Horizontal thin bright line across the screen, denotes the vertical sweep failure. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Vizio Televison & Video
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
My screen has horizontal lines across it
its the ram
mine does the same took ram out replace
Nov 24, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Televison & Video Logo
122 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
