Question about Nikon SUPER COOLSCAN LS-8000
Does not perform the autofocus - Nikon SUPER COOLSCAN LS-8000
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
I have a Canon EOS 500D and am using a standard 15-85mm lens. The image in my viewfinder appears blurred as do the digital settings you can see when looking through the viewfinder. The camera still...
There's a diopter control just to the right of the viewfinder. Adjust it while looking through the viewfinder until the display is sharp.
Apr 29, 2011 | Canon Cameras
Just bought a new eos d600 . How do I turn on the autofocus?
Set the autofocus switch on the lens to AF. Press the autofocus button on the camera (right on the cursor pad) to bring up the AF mode. Use left/right or turn the command dial to select the desired autofocus mode and press SET.
It's in the "Changing the Autofocus Mode" in the manual (page 83 in my copy).
Mar 23, 2011 | Canon PowerShot SD600 Digital Camera
Static subject, but 15-20 second delay after pressing shutter button before photo is taken. Manuel mode, autofocus lens. I have 7 other d70s that all perform fine.
have you contacted Nikon about this issue, they stand behid their products and since you have bought so many of these it seems to me that they will listen to you. Have you tried the camera in "auto" mode just to see if the problem is there too?
Mar 18, 2011 | Nikon D70s Digital Camera
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a Mac powerbook G4, and am trying to use skype with a creative notebook web cam. Skype does not recognise any camera in my skype video preferences. Any ideas?
Have you been able to work with your creative notebook web cam in any other function on your Mac
Powerbook G4? Probably not. PC cameras are not usually interchangeable with Mac Cameras for
what should be obvious reasons of platform, chipset, OS and IO diversity.
Here's your solution:
Enjoy image-perfect detail and clarity. Carl Zeiss® optics and autofocus keep images razor-sharp, even in extreme close-ups.
Overview 7228.1.0.jpg Performance
  • Carl Zeiss® optics: Get more detail and clarity from Logitech’s glass lens designed in collaboration with Carl Zeiss®, the global leader in camera optics.
  • Premium autofocus: Your images stay razor-sharp, even the most extreme close-ups.
  • HD video: QuickCam Vision Pro is a high-performance webcam capable of delivering 720p high-quality images* up to 1600 X 1200 pixels.
  • Higher megapixel performance: images never looked more real, thanks to a premium quality 2-megapixel sensor.
  • RightLight™ 2 technology: Adjusts intelligently to produce the best possible image, even in dim or backlighted situations.
  • Integrated microphone: A high quality microphone provides excellent, hands-free audio.
7229.1.0.jpg Convenience
  • Compatibility: Enjoy lifelike video on iChat or Skype – up to 30 FPS VGA quality. QuickCam Vision Pro also works with most leading instant messaging applications and delivers superior image quality compared to standard webcams.
  • Universal monitor clip: Mounts easily on any type of display or notebook computer.
Apr 18, 2009 | Creative Labs Creative Webcam
Autofocus does not work ( when ON ) with any lenses .
I remember reading a review of the K100D that mentioned that it had poor low light performance. I know mine has a really hard time focusing in low light situations. It does the sweeping back and forth & most of the time never ends up taking a picture. (Even when it bursts the flash to try to focus.)
I've just started experimenting by using a flash light aimed at the subject I want to focus in low light situations, and the camera seems to be able to focus & take a shot more reliably.
If this works, I'm going to rig up something to hold the flash light underneath the camera so that I can use it more often.
I will post an update if this works!
Take Care & Happy Imaging!
Glen
Mar 15, 2008 | Pentax K100D Digital Camera
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
53 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
