Question about Bosch Classixx WFO 2466 Front Load Washer
Sometimes wont start, but counts down by one digit
I have to either keep pressing the start button, but more than likely I have to slam the door closed for it to work.
  • 249 Answers
Solution ,is replace door electric lock inside machine
Posted on Dec 21, 2007
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
I am not sure how to set the time interval in the nap mode. It starts at 2 hours, and I can't change it.
Ok, this is the way it works, and I keep my clock radio for this feature alone. It is a 2 hour "count down" timer. It is set in 15 minute intervals. Supposed you wanted to take a 1/2 hour nap. Press the button but don't let go. As you hold your finger down the timer will start at 2 hours (2.0) and it will then go to 1.45, etc. When you get to a 1/2 hour let go and it will start counting down. If, in the process, you make a mistake, press the blue button and don't let go. Hold it down until it erases the setting and removes the NAP text from the front display. Release button. Start holding down the button again. Once again, the display will go to two hours, continue to press button, it will start counting back in 15 minute increments. Again, when it gets to 1/2 hour, quickly let the button go. As the clock counts down, you cannot see how much time is left on the clock. Press the button, quickly let go again. It will display how much of the 1/2 is left. When the clock counts down to zero, either the alarm will sound or the radio will start playing depending on what you set the alarm to do. Press the off button, that's it... (0:
Sep 01, 2011 | RCA RP3721 Clock Radio
2004 stratus power windows stuck in up possition
NO COST and fast PROCEDURE TO FIX IT, if just one window stuck:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
Jul 11, 2010 | 2004 Dodge Stratus
How do you set the timer on a Finepix F50D, I don't have the manual with me
Press the bottom part of the ring around the menu/ok button to activate the timer. Press once for 10 second count down and twice for 2 second count down. Then press the picture button as normal and the count down will start.
Nov 26, 2009 | Fuji Finepix F50FD Digital Camera
Dryer won't start unless I slam the door
Not normal. Check door switch. As a test you can jump it out to see if the dryer works then. if that does not help then , I i would consider replacing the starter switch.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Garage door stops and reverses either way-up or down-
If the light on the opener flashes when this happens, count the flashes (which indicate the type of problem) and consult your owners manual.  If you don't have the owners manual, you can find a digital copy online at the manufacturer's website. Also, check your manual for an adjustment that tells the opener how much resistance you want it to tolerate before reversing.
Dec 10, 2008 | Kitchen Appliances - Others
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
Aug 19, 2008 | Microwave Ovens
Bosch Classixx WFO 2466 Front Load Washer Logo
101 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
