Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Hp 4400 VIVERAQ will not print..it says print
Hp 4400 VIVERAA will not print..it says print successful, but nothing prints out?..scanner and copier work fine
How do I repair Paper jam message but no jam
First step is to unplug your printer, leave it unplugged for 30 seconds and then plug it back in.
Aug 03, 2014 | HP Hewlett Packard Laserjet Pro 200 M275nw...
Scanner failure-no longer prints
Hi, I'll give your situation a "stab in the dark" solution. It sounds like you are in the final stages of "scanner system failure". The beginning stages usually limits the all-n-1 to print only i.e., no scan and no fax but you may have such a severe scanner bulb situation that is preventing the print function and may be causing hazardous conditions within your printer and it will do nothing to prevent further harm or damage. Can you describe your situation a bit more detailed?
Apr 16, 2009 | HP Officejet 5610 All-In-One InkJet...
I want to install my hp 4400 printer to my coputer
Install the driver disk that came with it on your computer. Then connect the printer. Try to open something and print it - you may have to select HP 4400 printer - after going to file > Print. But that is the long and short of it.
I recommend going to HP.com and downloading the 4400 printer driver from their website however. It is often a newer updated version than the one that comes with the printer on the CD.
Dec 20, 2008 | Office Equipment & Supplies
Cannot scan
scanner will not support wireless or network scnning facility
Dec 12, 2008 | Office Equipment & Supplies
Visioneen 4400 Flatbed Scanner Print Driver 64 Bit Vista
It seems that your scanner is not supported in Vista.
You are going to get a new one or downgrade to XP.
Good luck
Nov 03, 2008 | Visioneer 4400 Flatbed Scanner
HP PSC 1410 ALL-IN-ONE Printer-Scanner-Copier
My HP PSC 1410 is not printing and it seems not to have any communication with my computer.
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
161 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
