Question about Motorola Mobility H670 Headset
Same as described by a few users! i put it on charge them the red ligth goes on. them blink, goes weaker then vanish. I already left it 2 hrs on charging even with light out. just came out from the box. cant go to set 3.2 (pairing it) because the blue ligth dont blink. can't even reset it... tried forever to push the volume button and nothing happens!
  • 1 more comment
  • Paulo Margarido Sep 03, 2009
    still a problem
    Thank you for your tip. I read the manual 10 times now, and tried everithing to test the headset. nothing happens.
    cant reset pushing the volume button.
    cant charge it (it goes fast to rest, ligth off)
    cant enter the pairing mode (no blue ligth)
    the best thing that i can do is when getting it out the charger, sometimes it blink purple for less the a second, then it's off and no signal of life.
    headset h670
    nothing happens.
    charging only last 10 seconds (then goes off)
    no sync blue light
    no reset (nothing happens when pressing volume button)
    Ok i think i'll try returning it tomorow.
    if battery is broken then in a factory defect and prob more that have same prob will have to do the same. 1 point less to equipement
    Top Expert:
  • 76,682 Answers
U need to replace the battery, the red light is a low battery indicator, a defective battery will not charge no matter how long u leave it on the charger.
Posted on Sep 03, 2009
  • 17,970 Answers
I have the same for an K1. Make sure that any devices previously paired with the headset are turned off. If the indicator light is not steadly lit in blue turn off both the other device and headset, WAIT 10 SECONDS, then turn headset back on. Wait for the indicator light to become steadily lit in blue, indicatinf the headset is now pairing mode.
More details you can find in the MOTOROLA BLUETOOTH®-HEADSET H670
I hope help you with this. Good luck.
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
NO PICTURE OR SOUND 6 BLINKS REPEATIONG ON RED LED STANDBY NEXT DAY TV WILL WORK BUT ONLY AFTER IT HAS BEEN LEFT OFF FOR SEVERAL HOURS.
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is that it takes few seconds time to start [ after few days it takes few hrs to start (your case) & then finally stops completely ].............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore --- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 06, 2011 | Sony Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Just recieved my plantronics 903 backbeat headset plugged it in to charge and just blinks red llight left charged for 5hrs and when unplugged wont come on
Try resetting the headset and see if that helps. Here is the users guide, the reset instructions are on page 10.
Below is the link for the Backbeat User's Guide for more information.
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
May 14, 2011 | Plantronics Backbeat 903 Bluetooth...
Sony, SXRD Projection TVKDS-55A2000 Was working fine, then picture vanished. We have red blinking light on front, indicating lamp. I presume that lamp need to be replaced, but TV has only been operating...
Same thing happened on mine, you need to replace the bulb, on our TV I have 2 kids so the TV was always on but lasted 2 and a half years which impressed the warranty people. From what I have heard the average life is about 2 years. I have the same SXRD TV.
Aug 10, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Battery
Is the green light you described the 'charge' light or the power light?
Jan 14, 2008 | Dell Latitude C640 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Motorola Mobility H670 Headset Logo
277 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
