Question about Bosch Washing Machines
I have a WAE24364GB washing machine and it goes through the wash cycle ok but will not spin, makes a buzzing sound, i had to remove the filter to remove items from the filter as i could not unscrew , please help
    Problem Solver:
  • 14 Answers
Clogged water pump?
Posted on Sep 03, 2009
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool washer will not drain
Well i think you should be looking in the filter? Or in the pump. These are the only thiongs that will stop it from draining or spinning! The machine will not spin if it has water in it. It will go into spin inhibit to protect the machine. Check for lost items and then look at pump/filter if nothing then replace the pump then you will be ok.
Jan 02, 2009 | Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
