Question about GE Profile JT912 Electric Single Oven
Hello I just bought the house and my GE oven door won;t close all the way in. Could you please help?
    Problem Solver:
  • 14 Answers
There is a latch in the top of the door that locks in clean mode . need to get it out of clean mode
Posted on Sep 03, 2009
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
I HAVE A DOUBLE OVEN GE MODEL JKP55DPEWW WHITE AND WANT TO REPLACE THE DOOR WITH STAINLESS STEEL,PLEASE HELP
When I removed the front cover there were other color door fronts stored in side. I would just order a SS door front from a dealer or parts supply house
Apr 30, 2014 | Ovens
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
Oven door does not close all the was.about 1/4 inch until it will close.the latch to clean the oven will not move
Let me guess, it's a GE. If so you probably have bent door hinges. They are a pretty week point on GE Profiles. You can go to - http://www.searspartsdirect.com/partsdirect/index.action - Type in your model number then select model search. You can get a parts breakdown and buy parts for most brands. Good Luck.
Mar 12, 2011 | Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
Oven door stuck in locked position. cant close the door. GE profile electric oven
You will need to replace the switches on the door lock motor, if they are the type that are rivetted onto the motor then you have to replace the whole lock mechanism. For pricing info, and to learn how to do the repair yourself, please reply.
Please rate my solution if it was helpful to you.
Thanks, Repairman45
Dec 19, 2010 | GE Ovens
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
My GE oven wont stop beeping it has an FO on the screen. All the buttons will not press. I just bought the house and have no idea if its done this before. Please help!!!! Chelsea
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Dec 12, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JT912 Electric Single Oven Logo
594 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
