Question about Kenwood VR-407 Receiver
Receiver settings or bad system?
I just set up the receiver and it only the front two speakers work. I have set up many surround sound systems before, the wiring is correct, I guess I just dont know the right setting?
    Top Expert:
  • Kenwood Master
  • 80,531 Answers
If it has a test mode for the speakers run it, if you are sure the speaker connections are all good and you trust the wiring there is a hard fault in the receiver and it will need to be repaired or replaced..
Posted on Sep 03, 2009
HELP! Surround speakers not working with 5.1 material.
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Rca rtd325w
This is usually a system setting on your receiver. Go into the Setup and make sure the configuration for your speakers is correct. But FIRST, make sure the surround setting on the receiver is set to Surround rather than Stereo. I know that might sound dumb, but you'd be surprised how often that gets missed.
Check out these weblinks for additional support.
https://www.google.com/search?q=Rca+rtd325w&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Dec 01, 2013 | Audio Players & Recorders
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
The rear surround sound speakers are not working.the front ones are and the sub woofer works fine also. everything is connected properly but have no idea what to do to make them work.can you please help
Make sure that the media you are using has the surround sound...eg. if you are listening to the radio then the rear speaskers will not work as the signal is not transmitted in surround...if you put a dvd in that has the dolby digital signal encoded on it then the rears should work....the rears will only work when you have the receiver in the surround mode..make sure the receiver is in the right mode...also, you may have rear speaker volume settings in the setup menu that may need to be set up..go through the manual and see if there is a setting for the rear volume...most home theater sets have this feature and it allows you to set up the system for different size rooms
Jun 11, 2011 | Sony DAV-DZ850KW Theater System
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Only front and center speakers work, not surround.
If by white noise do you mean the test tone generated by the receiver? If so, this is actually pink noise and it is internally generated by the receiver. I would make sure either in the menu or on the remote that you haven't accidently turned off the surrounds and double check the wiring to the surrounds. Good luck.
Feb 15, 2010 | Aiwa AV-DV75
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
Kenwood VR-407 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
