When unit is plugged in all the panel lights light up but then they go off and nothing will turn on.
  • 1 more comment
  • sherriedaugh Sep 03, 2009
    Thank you harry, what do you mean resolder tho? where do i look for a replacement?
  • 30 Answers
YOUR AC HAS A FAULTY ELECTRONIC MODULE,REPLACE OR RE SOLDER MAY WORK
Posted on Sep 03, 2009
  • Harjeet s. bola
    Harjeet s. bola Jan 07, 2010
    resolder means reheat all the joints on the prited side of electronic plate
How do you to troubleshoot a Panasonic Vierra tc-P46G25 TV that does not turn on?
Check for bad capacitors (they'll look bloated) on the power supply board. Also check the voltages on the power supply board with your meter ; they should be etched on the board at test point location(s)
Jul 16, 2014 | Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Won't turn on
This is a clear failure of the power supply or the control panel due to the power outage and so will require that the power to the unit internally is checked. Sometimes this can be due to a fuse blown out or a control panel failure within the unit due to the intermittent fluctuation.
Nov 30, 2011 | Pool & Spa
Turn on the car then click the signal light and nothing!!! no tic to light nothing could it be the signal light switch or a fuse?? please help!!
Try the flasher unit first, checking it costs nothing. Turn on your emergency flashers and if they work, get your owners manual and find the fuse panel locations. Inside the manual or the panel cover there will be a legend as to what is what. You will have two flasher units, one for turn signals and the other emergency flashers. They are the same units so just switch them, if your turn signals now work, but your flashers don't, then you have a bad flasher unit. Go buy another at any auto parts store and put it in the correct socket, you rarely use the emergency flashers so you want your new one in the turn signal circuit.
If that does not do it then you may have a broken switch which requires pulling the steering wheel off to fix. That is not an owner service thing. One bad light bulb is not going to knock them all out.
Jan 05, 2011 | Mercury Cougar Cars & Trucks
X10 mini controler will not turn off pool light
the unit is probably transmitting but the receiver on the lights is not getting an acceptable signal.
try placing your controller on a line closer to your main electrical panel.
Unfortunately x-10 technology is very unreliable its convenient but its also a pain in the ****.
Do the basics make sure the controller is close to your panel, make sure its not plugged into the same circuit that your appliances, computer or electronics are plugged into as they generate RF interference.
Smarthome.com sells several X-10 boosters, if your home has a 2 phase power get one that plugs into a 220v outlet that will "bridge" THE TWO PHASES.
May 09, 2009 | X-10 (MC460) Remote Control
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Oct 04, 2007 | Cyberhome CH-DVD 300 DVD Player
Problem
so you have 3 lights on the front panel power homeplug/internet wireless so whats the status of those lights ? do you have the unit plugged into a power extension cord - as this can cause problems are you using as a router or an extender ? download and install this software - it will detect all wireless signals - the SSID, channels and if secure
Sep 23, 2006 | NetGear WGX102 Repeater
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
