Question about Konica Minolta magicolor 2400 Laser Printer
Will the magicolor 2400w stop if one toner cartridge is empty . If yes can it be bypassed??
Removed each toner cartridge, shake it and replace it.
I don't know if this is the real fix but it worked for me at this time..
Posted on Sep 04, 2009
How do you clean the drum on a Minolta magicolor 2400W Laser Printer?
HI, I think you would be wise not to clean the drum, other than removing the toner dust. If you have problems with print quality, firstly check each cartridge in turn and see if the rubber toner roller is smoothly covered in the appropriate colour toner. If all is OK here, then empty the dust container. The dust container is in the back side of the the transfer band (drum), on the right hand side you will find an area where there is tape applied. Remove the tape to reveal the hole into the dust collector. Take care as there is usually a great deal of old toner in there, so it is a good idea to have a container at hand when you empty it. hen you have emptied it, you must of course reseal the hole. I have found the best sealer for this is the self adhesive alluminium tape which one can buy in any hardware shop.
Hopefully therafter all wil be OK.
Oct 20, 2010 | Minolta magicolor 2400W Laser Printer
Magicolor 2400W toner cartridges not empty
Have you tried taking the toner cartridge out of the printer and shaking it up a bit? Just make sure you do it outside or over a trash can. Shake it side to side.
Sometimes the toner bunches up and you can get some more life out of it by shaking it up.
Hope this helps
Thanks
Mar 24, 2008 | Minolta magicolor 2400W Laser Printer
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Can you bypass a toner cartridge on a magicolor 2530
If you mean to defeat the detection for a cartridge emptied of toner, yes. But if you defeat it for one, you defeat it for all of the cartridges. Also, this is very difficult and requires completely disassembling the printer to get to the sensor area. Instead, I recommend adding toner to the empty cartridge.
If you mean to defeat the detection for the presence of a cartridge, no. The cartridge is required to be in place for certain mechanics to work.
Aug 31, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
Konica Minolta magicolor 2400 Laser Printer Logo
93 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
