Question about Kenmore HE2 Plus Front Load Washer
I hit start after bulky bedding and machine wont start and then the delay signal goes on then the "f" for finish.
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
What is "delay wash" & how is it operated?
If you're washing machine is equipped with Delay wash.The delay start feature allows you to determine when you want the next wash programme to start. This is particularly advantageous if you want to use night time electricity tariffs or if the programme needs to be finished at a certain time, for instance when you come home from work. You can postpone the start of a programme by up to 24 hours. The display also indicates when the current programme will finish.
Aug 04, 2017 | Washing Machines
How do i override the delay start function
According to page four of the manual linked below, you can simply hit START after selecting 1. Menu item, 2. Crust colour, 3. Loaf size, 4. Mix-ins, 5. START or Delay Start Timer.
If the bread machine is running, and you wish to overide the Delay Start Timer, NOTE down the other options selected for Bread Type, Crust Colour, Loaf Size and Mix-ins; then press and HOLD the STOP/PAUSE key for 3+ seconds to re-initiate the breadmaking process. Re-enter the options, and re-start the breadmaker using no Delay Start Timer (Hit START in step 5.) or enter a new Delay Start time and then hit start
https://www.cuisinart.com/share/pdf/manuals/cbk-200.pdf
Feb 15, 2015 | Cuisinart CBK-200 Bread Maker
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Kenmore HE2 Plus Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
