Question about Viking Kitchen Ranges
The oven door is locked shut / open
I tried unplugging it to re-set and that didn't work.
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
if the oven is not working when the door is closed then the problem is in the door limit switch(this will be fixed inside the oven where the female lock is seated), this should work as you close the door.if this is good there will be a surge suppressor which will be connected inside the oven across the phase and neutral terminals check this if it is burnt you replace it.
Posted on Sep 04, 2009
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
I ran the self-cleaning and the door will not open.
or
Mar 06, 2010 | Whirlpool Ovens
I need to get my oven unlocked. The cleaning cycle went haywire
or
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
The oven door will not open after cleaning, and the oven cleaning has been done for over 1 hour? How can I get the door open?
or
Sep 16, 2009 | Kitchen Ranges
Oven door is locked and we can't open. We have tried everything including turning off the circuit breaker several times. HELP please!
or
Sep 12, 2009 | Kitchen Ranges
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Door locked
resetting thebreaker sometimes will work. if not try setting to clean. after engages the door to clean simply cancel the cycle the door lock/latch will cycleback . perhaps it just glitched shut.
Mar 12, 2008 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
102 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
