Question about Brother EM-530 Typewriter
Owners Manual for Brother Typewriter and problem solving for #3 key.
When you shift and hit the #3 key nothing types on the paper. Also, we do not have an owners manual. Can we get one
  • dawn9370 Mar 12, 2008
    Thank you very much. I was originally having trouble downloading but then was able to download successfully.
  • Anonymous Mar 31, 2014
    It types, but nothing shows up. plenty of tape, moves, tape is dull side to the paper, installed exactly like the manual says to, reset...
You can get the owners manual at http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=10 . Hope this helps some.
Posted on Mar 04, 2008
How do I turn the pitch beeping of and get started
Posted on Mar 05, 2008
How do I type numbers 1-0? I type 9 and get parenthesis.
The shift key is depressed. Hit shift again and it will go back to using the numbers. Any symbol on the top of the key will require the shift key to get it to work.
Jul 17, 2014 | Brother GX-6750 Electronic Typewriter
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
Feb 27, 2013 | Brother SX-4000 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from...
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Sep 02, 2010 | Brother EM-530 Typewriter
In need of a brother GX-6750 typewriter owners manuel please help
First press the Code key and Q simultaneously. That will reset the wheel position. If it clicks or otherwise fails to type properly, pull out the wheel and inspect it. One or more of the types may be bent. In that case, the wheel needs to be replaced. Good luck finding the part.
Feb 03, 2009 | Brother GX-6750 Typewriter
No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Jan 25, 2008 | Office Equipment & Supplies
Critical technical help needed
Open the top cover and you will see a switch on th right side that allows you to select alternate keyboards. Make sure it is set to the #1 position
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | Brother GX-6750 Typewriter
Brother EM-530 Typewriter Logo
509 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
