Question about Philips 32PT6441/37 32" TV
Its a phillips 28pw5324/05
The picture bends inwards on the edges?
  • doherty1 Feb 05, 2008
    ihave the same prob
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
The problem in your TV receiver. Some components in Horizontal and vertical deflection circuits must be faulty. Adjusting H & V frequency may also smooths the picture. Contact Authorisedservice personnel.. All the best !
Posted on Dec 22, 2007
Keyboard Remove
Remove the 3 Phillips screws that secure the keyboard to the computer.
Turn the computer right-side up, and then open the display as far as possible.
Turn the computer upside down, and locate the keyboard release access on the bottom of the computer, inside the battery bay.
Insert a flexible tool into the opening, and then press inward to release the keyboard.
Turn the computer right-side up, and then lift up on the top and left edges (1) of the keyboard until the keyboard releases completely.
Component replacement procedures 416. Slide the keyboard back until its top edge rests on the display assembly .
Release the zero insertion force connector to which the keyboard cable is attached.
Disconnect the cable and then remove the keyboard.
Oct 17, 2013 | Computers & Internet
I have a tedelex ec29187 with a funny picture. The sides seem to be bend inwards. A guy said they call it a east west problem. Help me with a solution please.
Ity is an East West porblem [Pin-cushion distortion] itself. You ahve to check its pin cushhion circuit to detect faulty component/s.
Apr 12, 2012 | Televison & Video
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
My Alesis Interactive Mobile Amp seems to have a dead battery. I was keeping an eye on the charge lights, and when it went from 3 green lights down to 1, I plugged it in to charge the battery back up. ...
change the battery, its quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
May 30, 2011 | Alesis TransActive Mobile PA System...
Battery has died how do I replace it?
you need:
e) some glue
... yes thats all.
here we go
DISASSEMBLY
ASSEMBLY
Jan 18, 2011 | Alesis TransActive Mobile PA System...
How can i prevent paper jams
ø Remove printer paper from its original packaging. Insert all unused paper into a large, resealable bag. Store the bag with the unused paper on a hard, flat surface away from extremes of heat and humidity to prevent curling, bending, ripping and wrinkles which can cause paper jams.
?? Remove only the amount of paper you need for a particular job from the resealable bag. Tap the paper stack on a hard flat surface to align the edges. Check the paper for rips, curls, wrinkles or bent edges. Remove and discard any unsatisfactory pages.
?? Insure all paper in the stack is the same size and type. Insure only paper types recommended for the HP All-in-One printer is being used. Recommended paper types can be found online at www.hp.com/support/inkjet_media.
?? Insure the HP Officejet All-in-one printer is not currently servicing a print job. Remove any original papers from the copier glass.
?? Insert the stack of paper into the input tray, short edge forward. Slide the stack forward until it stops. Do not force the stack beyond its initial stopping point.
?? Slide the paper width guide inward until the paper is held snugly in the input tray, but not so tightly that it bends the paper. Insure the stack of paper does not extend
?? Observe the printer during operation. Promptly remove printed pages from the output tray.
Dec 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
TV picture distorted, bending in from the sides
main board is cold solder. resolder main board.
May 31, 2009 | Televison & Video
Picture is distorted appears to bend inwards
I am assuming you are talking about the horizontal, if that is the case and the picture bends in from the sides it is likely there is an electrolytic capacitor dry or leaky, usually easy to recognise, look at the top of all the caps around the horizontal section and see if you can find one with a bulge at the top, replace it, look around where the scan coils are plugged into the main board and toward the horizontal output stage area, there are other things that can cause the same symptom however, I have found that to be the main cause. It is worth looking at the primary power supply stage especially the mains cap ( the largest capacitor there, usually 250v or higher,) remove it,( oh a word of warning- discharge it first, just in case) look at the bottom and look for leaks. if you have a cap tester, it will save time, if you can use and own a oscilloscope, look for ripples in the mains...hope that helps Phil
May 18, 2009 | Samsung Televison & Video
Rotating Dual Function Impact Plate on Standard Stapler
I have worked on those auto staplers off and on for about 15 years or so.They all have the same little option to ben the points of the staple inward or outward.The inward bend is more stable and secure.I know of no one who intentionally uses the outward bend.I believe it to be a marketing gimmick, no more.Good Luc
Mar 25, 2009 | Office Equipment & Supplies
TV picture has colors separated, image blurred
whats the model number of the set, But its sounds like the convergence ICs need to be resolderd.
Dec 28, 2008 | Televison & Video
Philips 32PT6441/37 32" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
