Question about Dell E770P 17" CRT Monitor
Smells hot - Dell E770P 17" CRT Monitor
  • 58 Answers
Get a new fan.
Posted on Sep 04, 2009
  • oloo Sep 04, 2009
    ...or blow out the dust.
I have a 2002 Mitsubishi Diamante the coolant fan will not come on. The gage says it isn't hot but it smells hot. What could be the problem ?
check fuses and relays -engines smells hot [all engines put out heat and smell hot ]could be nothing the engine could be running correctly or test the temperature sensor ,fan motors and fan circuit --if smells hot because of leak look for leak have coolant system pressure tested
Oct 15, 2016 | Mitsubishi Cars & Trucks
Smell fuel near carburetor in front.
The carb float chamber is vented to atmosphere and under certain conditions there will almost always be a fuel smell near the carb, especially for those with a developed sense of smell. Petrol is a liquid with highly volatile elements and in hot weather or a hot engine those elements will readily evaporate and then the vapours will drift where they will.
Any abnormally strong or stronger than usual fuel smell should be investigated and while most leaks will be easy to find with a cold engine and cold weather it is worth noting a tiny fuel leak can create a strong smell in mild or hot weather or with a hot engine and be virtually impossible to find.
It will probably be necessary to remove the air cleaner to check for carb flooding and it is also worth noting in the case of an engine driven fuel pump there is a possibility of a leak into the engine crankcase.
Jun 26, 2016 | Cars & Trucks
DG 50000. Why is there a hot burning smell when it is running?
The motor, the pump, or the heating element could be getting ready to fail.
Oct 03, 2015 | Indesit Dishwashers
New dryer smells hot
It is not unusual for new appliances, espicially high heat ones like a dryer to smell hot. Also if this is your first gas appliance it might smell different than your old dryer if it was electric. Keep an eye on it when using it to see if you see any smoke. Also check your venting to make sure it is all clear with no blockage.
Jan 10, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
Check engine light + hot smell after driving only 20 miles
Make sure your alternator is not seizing up making the belt slip and get hot enough to smell of burned rubber.
Feb 09, 2010 | 2003 Ford Escape
My honda accord wagon smells hot i stop running car, ther,s no leaks do i need a termostat?
You may have a bad thermostat or a weak water pump or a clogged radiator. Smell does not indicate if its hot. The gauge or coolant light might suggest its getting hot. You may have a fuel control issue that is overheating the catalytic converter which would smell or an oil leak that is dripping onto a hot surface causing a smell. You may have a real small coolant leak that you cant see that could cause this also.
Sep 09, 2009 | 1995 Honda Accord
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Dell E770P 17" CRT Monitor Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
