Question about Mitsubishi CS-32309 32" TV
Re tv: cables have been unplugged...which ones go
Re tv: cables have been unplugged...which ones go where ...we get the picture but no audio...
  • 59 Answers
Scart or RCA connectors?
if RCA then the red and white sockets are left/right audio in
if scart then check to see if plug is loose.
Posted on Sep 03, 2009
How to fix problem with TV that has no sound or picture?
Take it to a Samsung repair centre. It boards that need replacing, and there are many. You have to swap out the right ones.
Mar 28, 2017 | Televison & Video
Why do I have a picture but no sound after unplugging and then replugging cable to tv?
Check whether volume is set to Zero. If it is found OK, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 13, 2014 | Curtis-Mathis CM19011 TV
There is problem in my samsung 21 Ultra Slim Flat TV. there is no picture but only sound when connected to satellite receiver with AV cable. why is this??
You need to be more specific . There are usually three types of "A/V" cables. There is the HDMI cable. One cable many wires inside and the same plugs at either end. There is component. This has 5 RCA plugs at each end. They are color coded so you dont mess them up. However, there are 2 red ones. One of the red ones is paired with a white one and carries the left and right audio. The other, red video. The last type is the old style and there are 3 cables - red white and yellow. Yellow is the video and the red and white are left and right audio. The easiest way to prove what is bat is by substitution. Swap receivers, and cables is one way, or use a DVR with the same connectors. Oh and does your tv's audio work at all? (Dont have it muted and or the volume all the way down. or a headphone in the headphone jack). One way to test the audio cable plus TV is just unplug the component audio cable from the receiver and touch the center pin with your finger with the volume way up. SHould here a hum if its a good cable and tv's input. One way to sub for the tv audio is to patch the satellite audio out to an audio in of an audio sytem like an FM receiver. If its good into that system and flunks the hum test, your tv is suspect. Have fun.
Jun 09, 2014 | Samsung 50 in. Plasma TV
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
No sound but picture on an RCA L32HD31R
Check all ur tv inputs cables connections from the back of the tv,for like AV components and or HDMI cables for losed connections or damages cables wires.If u have cable boxes,satalite boxes or telicom compannies boxes and it plug in 24/7?Yes?Unplugs,replugs those boxes and the tv also back about an hour later.For those boxes to reboot and upgraded it softwares and the tv to do a resetting itself back to the tv factory settings.Than goes into the tv menu,go to the tv Audio Settings,to do a whole resetting to all the audio settings back to the tv factory Audio Settings.These steps,will help for ur tv to have and to get it audio sound back again.
Nov 29, 2011 | Televison & Video
Vertical line flashes on tv screen
Picture problems are surely among the most common technical issues experienced by home TV viewers. Such problems may manifest themselves as pixelization or frozen pictures, intermittently flashing pictures on one or more channels, static or audio degradation, or channels that are missing altogether. To address these problems, you can always contact the technical support department of your cable TV provider and have them walk you through troubleshooting steps, but it is wise to learn how to fix problems like this on your own without consulting any outside help. Doing so can save you lots of valuable time and money in the long run.
1.Reset your cable TV equipment by unplugging the power cords of any digital cable boxes/DVRs you use in the home. Count a full 30 seconds and plug the equipment back in. After allowing the device enough time to complete its boot cycle, check the picture again for any improvement. A cable box in need of a reset is by far one of the most common causes of many different picture degradations, so this is a necessary first step.
2.Check the audio/video connection cable or cables that attach your cable service equipment to your TV. Loose or malfunctioning cables are also a very common cause of picture degradation. Secure any cables that may have come loose and replace any visibly damaged cables. If you think the cables may be failing, you can temporarily test them by plugging another audio/video connection cable from the cable equipment to the TV and checking for any improvement.
3.Scan through your entire channel lineup as well as all the input channels on your TV. This will help determine the scope of the problem and how to most effectively troubleshoot the issue further. If you see the vertical lines on only one or a few cable channels, the issue is much more likely with the broadcaster or your cable provider, and you will need to report the issue to your provider. If you see the vertical lines on all channels and all video inputs, it is more likely that the TV's picture components are beginning to fail, and you will need to have the TV serviced or replaced altogether.Thanks for using FixYa, hope this will help your problem.
josie
Oct 19, 2011 | Televison & Video
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
