Question about Canon PIXMA MP830 All-In-One InkJet Printer
4 out of the 5 cartridges are flashing on my printer- I assume this means that they are out of ink. However, the smaller black one is not flashing and appears full, but the printer still prints blank pages...why is it not using the black ink from the smaller cartridge till that one runs out? thx
Canon mg5100 doesn't use switch to larger black ink cartridge
my printer CANON mg5100 still has the same problem...I bought 3 printers ! THe quality of them is in 1 to 10 =2 or 3 ...The same issues: always using colors instead BLACK too much head cleaning.... This printer MG51000 is for sure the WORST i ever bought.......
Jul 17, 2012 | Canon MG5150 AllInOne Printer
I changed my ink cartridges (x2600)and now when i try and print i get a cartridge stall message. Also the letters J and E flash seperatly where the number of pages would appear. I tried taking the ink...
I had the same problem. E J kept flashing. My black cartidge on the left side wasn't set correctly. It was a refill from a store an was smaller and looked different than the color . It was blocking the ink carraige from moving. I took out the black and pushed it back as far as possible. Now it works fine. Hope it works
Aug 31, 2010 | Lexmark X2600 InkJet Printer
Flahing E 5 and lights blinking on black and colored ink
Hi, the E5 means that:
The ink cartridges are
not installed[1401],
or a non-supported ink
cartridge is
installed[1485],
or the ink cartridges are
not installed
properly[1687].
Try with diferrent ink crg., Be sure to use genuine. If that doesnt help, the problem is in printer head, or logic board.
Hope that helped.
Jul 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
I have run out of black ink in the large cartridge. Can I make the rpinter use the smaller cartridge to print black and white?
No, the larger cartridge is used for text printing only.
The smaller cartridge is used to add black to images instead of using the color ink to make a composite black.
Don
Oct 23, 2009 | Canon MP610 Photo All-In-One Printer
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Black & colour cartridge lights are flashing and error code 2
When the black and color cartridge lights are flashing this means that there is an ink cartridge error. To solve this issue, you need reseat the ink cartrdige. If this does not correct your issue, you will unfortunately need to replace the ink cartridge. Make sure you are not forcing the ink cartridge into the printer as it can damage it.
Jan 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Does not recognise the smaller black ink cartridge
This machine is not meant to switch between the two black cartridges. The large one is used when you are using black only, and the small one is used when you are printing in color.
Jul 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MultiPASS F60 Cartridge
"K" simply means black. Replace your black ink cartridge and it will be fine.
Mar 10, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
