Question about Fuji FinePix S3100 Digital Camera
Fuji FinePix A400
my camera won't turn one.
even with new batteries & a charger,
i've tried many things... SOMEONE HELP?!
  • 68 Answers
Take the batteries out and clean the contacts
Those at the bottom of the battery compartment you can clean with the eraser at the end of a pencil
do the same with the lid.
Make sure the batteries are fresh/charged
When you close and lock the compartment lid squeeze it shut then turn on- it may be a contact problem.
If this fails then it will be a repair shop job
Posted on Jan 07, 2008
Finepix JX420
Hi Iman, Try Lots of info there. I hope this helps.Jimmy
Apr 11, 2012 | Fuji FinePix Cameras
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( ).
Jan 19, 2011 | Fuji FinePix A400 Digital Camera
My niece owns a finepix fujifilm camera that will not come on even after she charges her battery. She thinks it maybe the charger thats causing the problem. What other ways can she charge her camera if the...
Non..You will have to replace the charger or at leat have it checked. Find someone with a multimeter ( electronics shop) they will surely test it for you free.
If it is not the charger then try cleaning the battery terminals inside the camera to ensure good contact or even a NEW battery as this one may have reached its life expectancy
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Fuji FinePix S7000 Digital Camera
Fujifilm finepix v10 does not turn on. when plugged into the charger the red light that indicates it is charging turns on, but even then the camera itself does not turn on. a new battery has been tested,...
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Jan 03, 2010 | Fuji FinePix V10 Digital Camera
When trying to initialize the card it just says card error
Fuji finepixs FinePix A400 says card not initilized
HI, I have been using my camera Fuji finepixs A400 for 2 yrs. Then suddenly it pops up with "card not initlilized".
Jul 31, 2009 | Fuji FinePix A400 Digital Camera
I need d sofware for fuji finepix A400 digital camera asap thanks
download it from Fujifilms website
Nov 21, 2008 | Fuji FinePix A400 Digital Camera
Fuji finepix a400 focus error
I have the same camera and have devised this solution. Remove batteries, leave for about 10 mins then replace batteries ( make sure they are in good condition, Cover the aperture whilst switching it on and it should work - mine did on the 2nd attempt.
Good Luck
Jun 20, 2008 | Fuji FinePix A350 Digital Camera
Card not Initialized
Can you get into your camera's menus? If you can, there should be an Option under your Setup menu to Reformat card that might fix the problem. This happens sometimes with the memory cards, they just need to be reset. Unfortunately you can lose your photos sometimes when it happens, so if it's happening a lot you should buy a new memory card.
Jun 06, 2008 | Fuji FinePix A400 Digital Camera
Fuji finepix a330 digital camera says "low battery"
To help rule out if the battery, camera, or even your charger I would suggest to first clean all the contacts. This can be done with some rubbing alchol and a q-tip, make sure you get the contacts in the camera, directly on the battery, and your charger. Wipe off any excess alchol and let it sit for a minute or two so the alchol can evaporate. Give the battery a good charge and see what happens. Where did you purchase that replament battery? If what was under 10bucks I would suspect it's the battery, there are a ton of crap battery's hitting the market, always stick with name brand. Another possibility is that the charger could be sending the wrong voltage to the battery causing inproper charging, or even the chargers power cord could be sending the wrong voltage to the charger. Anyway I'm done rambling, It's 12:15am and I have a 70hour week starting in 6 hours so i'm outta here. Hope this helps. And here's a link to your manual if you need it: L8R Good Luck
Sep 16, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix S3100 Digital Camera Logo
43 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
