Question about Uniden Cordless Phone
How do I register the phone to the base? - Uniden Cordless Phone
My phone will not register to the base, help!!!1
Posted on Oct 15, 2009
Directions for exai5680
Posted on Sep 07, 2009
    President:
  • 778 Answers
For most cordless phones it's just putting the phone in the base cradle for 5 or 10 seconds. Have you tried?
Posted on Sep 03, 2009
  • Frank  Fernandez
    Frank Fernandez Sep 12, 2009
    Did you get the phone paired to the base?
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Phone will not register with base
Would you try this procedure:-
First on the base station..press and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Nov 14, 2009 | Siemens Gigaset S440 Cordless Phone
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
STILL SAYS "PLEASE REGISTER"
I think this may be the answer. With multiple handsets reading "Please register" and a "working" base station (w ith dial tone). If you bring the remote units to the base station and place them on hte base, they will register and stay registered after you return them to the remote base. It doesn't say this anywhere in the instructions as it gives you the impression the remotes will register from their own base.
Jan 04, 2008 | GE 25932 Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Uniden Cordless Phone Logo
240 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
