Question about Minolta Di3510f Bizhub Copier
Minolta CS Pro Error Code C0070
The toner was replaced and looks as though it is lined up correctly but I still get the error code. Any ideas. The copier has been powered off and back on after a few minutes.
    Problem Solver:
  • 8 Answers
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Posted on Dec 08, 2007
Malfunction code C0070
mam/sir Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 09, 2012 | Minolta EP4000/5000 CS/PRO Copier
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Error code c0070
Toner bottle rotation failure. I have a tip posted here at Fixya that deals with this code. Here is the link for you.
http://www.fixya.com/support/r3798733-konica_minolta_copier_service_code_c0070
If it works please return to this post and provide feedback.
Thanks.
Jun 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Error code c0070
A error code C070 has to do with the toner hopper motor. Did you just put a new toner in. If so, carefully remove it and turn the copier off & close the front door & turn it back "ON" and let the copier come to "Ready". Once it is ready, reistall the toner bottle and close the door and see what happens. If it is not cleared you most likely have a problem with the "HP" flag for the toner bottle. Good Luck..
Oct 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
It is showing error code c0070
Insert correctly the toner cartridge,open the front door and press the service/trouble reset switch placed in the top left side. and close the front door.
Oct 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Panel shows error code Cof24
(Automatic Image density Correction) basicly this sensor looks at the drum and determines thew drums ability to hold toner and image. The sensor could have toner spilled on it or the drum needs to be replaced or the senor has gone bad
May 29, 2009 | Minolta EP1030/1030F CS/PRO Copier
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta 5000 copeir
the only code that i see in the service manuel is : c0070, c0071 and c0072
All of these's code refer to the toner replenishing, check if your bottle of toner is correctly position....
To make sure, take the bottle out and close the front door, the copier replace the mechanism correctly, after that replace the bottle to it's position and close the front door....Please let me know !
Mar 27, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
2,427 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
