Question about Toys
Because leather seat requires mending on my range rover 1988 how do I remove the seat?
    President:
  • 2,976 Answers
From under the vehicle, unbolt the tracks that the seat slides on.
Posted on Sep 03, 2009
How to Clean Auto Leather
I use Griot's Garage leather care products and have been very pleased with the results. Thy have a leather care spray that will clean light dirt, but very dirty leather may require an interior cleaner that is PH blanced so it does not dry the leather out. Then after the leather is clean, allow it to warm in the sun and apply leather care, leather 3 in 1 or leather rejuvenator, all excellent products, that will sink into the leather and keep it supple and prevent cracking. I would not use shoe cleaner as that leather is dyed differently and may be too harsh for fine leather as is used on vehicle seats. Also keep in mind that in most vehicles, only the leather "seating surfaces" are actually leather, the rest is matching vinyl so be sure to test anything you use on a non-visible spot first.
As for repairs, there are kits available to repair holes and rips. Many are simple and require a small patch behind the leather and the placing of a color matched "goo" on top of the patch and pressing of a grained paper over the goo to resemble the leather graining, so it looks similar when dried.
Best of luck.
Nov 23, 2014 | 2004 Lincoln Navigator
How to mend a tear in.a leather sofa?
No you cannot glue leather you cannot sew leather either it has to be done with a vinyl repair kit try to find somebody local in your area that does leather vinyl repair or have the cushion recovered
Aug 31, 2014 | Furniture
How to wire a range rover power seat
There are 4 electric motors under each seat and a 5th inside the back rest. Also under each seat is a module containing the relay and memory module It is possible to run new wires but the job will be much simpler if you have (or can get) a pair of original wiring harnesses to go between the module and the harness behind the centre console (remove ashtray, lighter and storage bin) Spade terminals can be used if the module is missing. Make sure the wiring colours all match.
Of course, this is a simplified explanation. Go to Rovers.net for more detail
Jul 29, 2014 | 2002 Land Rover Range Rover
How can I reset the airbag warning light in my 2006 range rover
recheck connections for the seat belt and see if the computer needs reset..
Dec 16, 2013 | 2006 Nissan Titan
Installing range rover evoque dog guard VPL VS0082
You have a job on your hands. Remove rear plastic boot protector then unscrew the chrome bolts into the floor. Next remove side panels and ensure you disconnect light on right and 12v socket on left.
The side panel metal brackets are a breeze, but to fit the lower brackets one left and right and one central require you to unscrew the seat brackets into the chassis. I cant see how they can be got at nor can I remove the rear seat uprights to access them so, ive just bothered with the upper brackets. Doesnt move and took me half the time :)
Jun 03, 2012 | Land Rover Evoque Cars & Trucks
1988 range rover [ over heats going up hills] thats all i know. it was given to me .
if no water leak it sonds like a bad radiator ,or impeller in the waterpump broken, if water leak ,. the headgasket can be bad , then the engine overheat because of poor water circulation and boils.
Dec 05, 2010 | 1988 Land Rover Range Rover
Acura mdx..cracked leather seats..should I buy it?
re-upolstery can be expensive and requires removing seat[s] a good quality set of seat covers could be had for app.$100. or less
Sep 22, 2009 | 2001 Acura MDX
1991 range rover passenger seat doesn't move
You could try swapping out the seat switch from the other side if you are just trying to move the **** portion forward or backward. What usually goes wrong is the seat switch gets corroded and needs to be disassembled and rebuilt. The opposite seat switch will no fit the other side and mount but you can finesse it around to a position where you can make connectioin.
To remove seat switches - Use a small screw driver to carefully pry up the button control knobs (**** and back knobs) on top of the switch housing. Next, remove the cover plate and there you will have 2 screws exposed to remove the switch.
Mar 22, 2009 | 1990 Land Rover Range Rover
Toys Logo
37 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
