The following ink tank cannot be recognized - Office Equipment & Supplies
SOURCE: INK TANK
U150 is a 'faulty electronic chip on the tank' error. If you installed a new Canon OEM tank then probably the chip on the new tank is bad.. Take that tank back for a replacement.. If you installed a Clone(non-OEM) tank, then that one will only work if you retrieve a chip from a known good OEM tank and glue it on to it. Clone(non-OEM) tanks all come without chips.
Posted on Sep 26, 2007
SOURCE: I have a U043
Hold down on the Stop/Reset button for 6-10 seconds just after re-installing the cartridge. the pop up window will ask you or tell not to do it but click the warning 3 times and it should clear. .
Posted on May 08, 2008
SOURCE: MP500 ink tank cannot be recognized error U043
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Posted on May 14, 2008
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Posted on Jun 25, 2008
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
The following ink tank can not be recognized on mp620?
i would not refill my own cartridge tank with 3rd party if i were you. stick to OEM print carts only . Canon is very pickey when it comes to using OEM cartridges. call Canon direct to get new OEM cartridges 1-866-226-6634
Jan 03, 2012 | Canon PIXMA MP620 All-In-One InkJet...
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Hello the following message comes up when i have put some new ink in. U043 the following ink tank cannot be recognised. any ideas? i have tried 2 ink tanks and same message comes up.
This Canon ink tanks has a memory chip.Try clean this chip with piece of cotton and some alcohol.Clean the contacts on the print head too.Sometimes happen this chip going to fail and printer not recognize it respectively not recognized and ink cartridge.In worst case your print head may be defective.
Oct 29, 2009 | Canon MP610 Photo All-In-One Printer
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
533 people viewed this question
k24674
